Project Information
With the completion of the purpleheart prototype, I decided to build a pair using a piece of burmese blackwood that I bought a couple of years ago. The blog to follow along with the build is here. The vital specs:
- 55 degree bed on one, 47 degrees on the other (this was not intentional, ugh)
- 1 1/2" wide O1 iron, 5/32" thick
- 6" long
- About 2 1/2 lbs. each
These were fun and quick to build after doing the prototype. They would have been quicker with less hassle had I not done peened through rivets. Oh well, live and learn. The last pictures show the whole family. As for the plan, I only need one, so the other will be offered up after the irons get heat treated. Thanks for looking!
Gallery
Comments
Premium Member
Those are very nice… a simple yet great design. It looks like they cut nice too.
Thanks. The irons are not heat treated nor are they honed. The mouths are incredibly tight.
Nice curlies nonetheless and great work on the planes Brian,
they sure look nice, good job!
I'm excited to see how it cuts when they are hardened and honed. Should be nice, I hope.
All class.
If they cut as well as they look …. they are just sweet.
COOL planes…
Rock and roll.
High quality and home made to boot. Ya can't beat that.
Thanks for all the comments. It only looks like I have been making them like a mad man. Some of the planes have been in various stages of completion for a little while, I just finally took the time to take pictures and post.
Awesome, Brian!
Love the Blackwood
And the shavings!
Terry, it's possible that I used alder knowing it would produce nice looking shavings for the pictures… :)
My land your good at this.
Brian, are you heat-treating the irons yourself?
Curious what your heat source is since I'm having trouble getting 1/8" thick O1 to critical temp with mapp gas. I also tried a propane weed burner, but that's too much.
Oh, wouldn't a proper forge be nice! :)
Terry, I found a local brick supplier that carries fire brick. I picked up 8 bricks at a whopping $2.21 each (that's actually a very good price). With something to retain the heat like a few fire bricks, a regular propane blow torch will work just fine. When I get to that point, I will take several pictures.
Thanks, Brian.
I have a dozen bricks, but think a few more would help contain that heat…will try again!
Terry, what kind of arrangement are they in?
Brian, they are arranged differently for each project;
had a few broken recently.
