Showcase cover image for Outfeed table for Ridgid R4512
Project Information
I recently built this outfeed table for my Ridgid R4512 table saw. I was in need of one as a future project will have me cutting some full sheets of plywood. It is a frame made of 3/4" plywood with cross members that are dadoed to line up with the miter slots on the saw. I then topped it with hardboard. I wanted it to be as light and as strong as possible.
I made adjustable legs out of plywood. I drilled a hole and then squared it out for a square nut to be able to tighten the legs from the other side. The legs are attached to top via hinges.
To attach it to the table saw I cut a 2×4 down and cut a dado in them for the table to sit in when I need it. I attached those using the t-track in the bottom of the rear fence rail. The whole table can be lifted off and folded up and put away to make room.
Gallery
Comments
Efficient, functional and elegant solution. Nice work.
I like the size of it!
Nice work.
I see you use a tricycle to move those heavy sheet goods around the shop … And yes, it is a nice outfeed table, and the torsion box should keep it dead flat.
Thanks for all the nice comments.
GrumpyMike - yes the tricycle does come in handy. Lol the joys of sharing a garage/shop
