Project Information
Offcuts turned into More Fund Raisers and gifts for someone..
Dean at Living Timbers in Penrith had some "give away" offcuts of small Camphor Laurel slabs.
Home - Living Timber Co
They were about 30-35mm thick and big enough for serving boards, so I ripped the board in the bandsaw then put them through the thicknesser.
These pieces were offcuts of the previous boards which I have biscuited and glued together after attempting to book match them.
With such good figure and colour I had to try to use these offcuts.
I used slow epoxy to fill the voids and cracks but on the prettier of the boards I was disappointed with the result as there were lots of fine cracks and pinholes after the initial sanding.
I have a pack of "IceEpoxy" resin, but haven't as yet been game enough to use it, but I think now is the time to start that learning process.
Ice Epoxy Crystal Casting Resin - CREATE PIECE OF ART
There was lots & lots of sanding, filling with epoxy plus Starbond CA the polishing with "Food Grade" Kustom Grit Step#1.
Kustom Grit Superfine Abrasive Paste | Kustom Creations
They came up okay and should do good [I'm my own worst critic] .
Cheers Peter
Cheers Peter
