Project Information
Here's a new awning I made to go over my back door after the old aluminum one collapsed in a snow storm. The drawing of the awning is what I did in SketchUp before building it. It is made from pressure treated wood. The top is made from inexpensive decking boards. I wanted to use cedar but budget concerns prevailed.
Gallery
Comments
· Registered
That is a neat design. It should do the trick and hold a lot of snow!!.............Jim
· Registered
Very nice. Looks great and sturdy too.
· Registered
That is really eye catching. Nice work!
· Registered
Cool design but I can't help but wonder if water runs behind the awning where you would normally have flashing.
· Registered
Water leaking behind the awning hasn't been an issue yet, probably because the top piece of the awning sits just below the prominent bottom edge of a layer of shingles on the house (hard to see on the photos above). I'll keep an eye out for leaking water though and report back if I end up adding flashing. I have some extra copper flashing I'd set aside for that purpose but ended up not using it because it didn't seem necessary.
· Registered
Copper sounds like an attractive choice if you find it necessary to install some flashing.
