Project Information
I'm still relatively new to the whole ring making process (been at it for half a year or so). Here's a couple rings I made recently.
I only use reclaimed wood.
The first ring pictured is cherry, and maple.
The second is poplar, and hard rock maple.
I've tried tons of finishing tactics, and I finally ended sealing rings in CA glue. Polished with canola oil, and beeswax.
Gallery
Comments
Hello CalebGJG
Welcome to LJ's
Nice work on the two wood rings
I will make several in the future for friend but time is short !!!
Thanks for sharing
Thank you Diggerjacks.
I'm always open to any critique, or how to better my work.
Best of luck with your rings!
Nice looking rings. How did you make the rings? Did you turn them on a lathe, hand carve them, or use some other method?
Thanks max!
I don't have a lathe. I may get one for christmas (fingers crossed).
I cut the stock with a tenon saw, and plane it down as close as I can to the dimensions (I have them in my shop).
I then bore the hole with an auger, depending on the size needed. I can usuallly get it within . 1-.3 mm or so.
I then file out the interior, and use 220 grit-500 grit-1200 grit affixed to an old rasp to get the correct size. I constantly check the mandrel, and my caliper.
I then cut the exterior as closely to finished size as I can, with my coping saw. From then on out, it is a lot of sanding.
I affixed 3 sanding pads to a granite block, which makes the sanding go much quicker, and more accurate than spot filing (at least for me).
After it is dimensioned, I finally hit it with some mineral spirits.
Burnishing hasn't been any trouble for the CA glue I seal with. It takes around 15-20 coats on the exterior, and 10 or so on the interior of the ring. I made a mandrel jig, so I can seal a few rings at a time.
I again sand at 1200, and apply a last coat.
I then sand lightly at 1200, and apply beeswax and canola oil.
Last thing I do is polish it with a micromesh guitar cloth. It is the best thing I've found for the job.
If anyone has any suggestions, my ears are always open.
Thanks again.
Great Rings…they are the bane of my life…I would hazard a guess that out of every eight I attempt only one survives. I recently got a few of eric Goetz's Ring Core [see bangle Guy]. I have started the process to make them and will post asap…
Regards….George
