Project Information
This is my very first project in which I used dovetail joints. I am newer to woodworking and was given an older Leigh Dovetail Jig from my father. He gave me no direction as how to use it so after a lot of research online (thank God for the internet) I had a pretty good idea how to use it. I wanted to build something that was a simple design so that the dovetails would stand out as the focal point of the project. After all I spent a great deal of time learning all I could about this jig and cutting dovetails so I wanted them to stand out on my first project. I had been planning on building a good solid step stool for my boys to reach the sink so I went with that.
Due to the fact that this was the first time cutting dovetails and using the Leigh Jig I didn't want to screw up a lot of really nice wood with mistakes. However you need straight non warped wood in order for the joints to line up right. I had some extra bass wood that I decided to use for the steps.
It took me a little while to get the dovetails just right but once I had the right settings the cutting was a breeze. The dovetails locked together very nice. I used a biscuit jointer to attach the top and bottom step. The bass wood has a nice looking grain so I finished it with a shellac finish.
When it was finished I tested the joints by standing on the top step and making a few small jumps. It didn't budge so all in all I am very happy with it and I don't mind seeing it in the bathroom every day!
Gallery
Comments
Dovetail jigs can be rather difficult to set up. It looks like you figured it outjust fine!
Welcome to Lumberjocks.
Nice job. The Leigh jig is confusing, but has great instructions. Looks like you found what you needed.
Yes and the little Leigh demo video on youtube made it look so easy! I only had the jig so I had to download the user manual online and then order the bits and guide bush. Once I found the exact setting though it was very easy and went fast. I suppose thats why they include a chart in the manual to record your projects settings.
Very nice !! I'm still trying to make dovtails, mybe some day. Welcome to LJs
Welcome to LJ's as a first project it cuts the wood…..
I went with handcut dovetails early on building a wooden toolbox, but that was on the front of the drawer on the back I used pegged mortise I used screws with plugs and dowels. It was all about different things and a learning experience. Still have the box but the next one will be a lot nicer.
Dovetails look great! I look forward to what you will use your new found skill on next!
I still have my first ones to cut. You did it now the rest should be easier, right?!
