Project Information
The only place I could find room for the router was under the bench. Since this is my first try, I used as much scrap material for all the R&D. I still have to add a couple of features and work with them. Then I will make a permanent unit mounted under the bench.
I welded up some slides and a locking mechanism to make it solid when I'm routing. The melamine for the table is one and a half inches thick, 34 inches long and 23 and a half inches wide. I have room for the fence with no problems.
Well this is where I am at today.
No.1…Cutting my first dado with my new router setup.
No.2…Router and lift installed and working on a fence.
No.3…Working on my second fence.
No.4…ready to slide back under the bench.
No.5…Router and lift installed with first fence.
No.6…Miter track and miter installed.
The next is the dust box underneath the table and the dust control. I still need to make a guard for the router bit to keep my hands out of trouble.
Any suggestions or critics are welcome. Thanks for looking. Rand
Gallery
Comments
· Registered
Nice, it is going to be one big router table!!! Like your dog, what kind is it?
· Registered
thats even easier than you let on ,
those are LIGHT beers (LOL) !
· Banned
Definitely a big router table…Very nice and a lot of storage undeerneath. Are you going to mount that 7815 in the lift? I have the 7815 in ine of my router tables and it is a workhorse.
· Registered
Nice work, Rand. That's going to be a good setup
· Registered
Everything sounds great! My only suggestion with your removable fence would be to use two pieces of T-track. Run them to the back of the bench so that, when you need to, you can slide the fence off. Just an idea… cant wait to see the finished product
· Registered
rand that looks great when you are done come on over and you can make 1 for me :)
just kidding but i do need a better router table that the 1 i have now post pics wwhen it is done
· Registered
Looks good.
Quick, someone call animal control, there is a wolf loose in Rand's shop.
· Registered
gregb..I'm tossing around the T-track and one that swivels. What ever I do, it has to be flush and not interfer with cutting 8-12 foot stock.
Patron…I love the new self portrait. How did you hold the camera?
Greg the WhoDat…Yes, I am gong to use the PC and a woodpecker PRL. I wanted the V2 but I'm afraid the little wheel might stick up. Does any one know? Seens to me that it should be flush, but I've never seen one except on screen.
ohwoodeye…she's just a little one and only takes little danty bites.
eddy…I'm loading the truck now and will swing by and pick up the material on my way…...uh I can't get the chair in, to many tools, too little truck…oh well…
· Registered
watch it there men ,
i lift my leg ,
and my fangs ,
for treats !
· Registered
Excellent concept and engineering skills for multipurpose applications…well done.
· Registered
Sounds like a great plan cant wait to see it complete
· Registered
Hey I like the Makita Lithium Ion drill and impact set in the back ground. Looks like the low profile white version. I have the original green with the 3.0 amp batteries and I love them, of course I worked for Makita for about three years a sales rep. and fell in love. Is that an old door your using for the router table? looks smooth and solid.
· Registered
Juan, Actually it used to be a desk top. The dark side is the old top. I laminated the bottom with a maple Formica to seal out the moisture. I liked the lighter side and used it for the top.
I've been a fan of Makita and Hitachi for 40 years or better. Rand
· Registered
Wayyyyyyyyyyyyy, too cool!
It's almost like mine!
I smile, I can see we went through some of the same proceses.
Best thoughts,
Mads
· Registered
Mads, I got stuck trying to make fences that are interchangeable to use on the router table, drill press and band saw. I haven't made the fence attachments because I don't know if the heavy grain particle board base will hold the T slots.
I am going to use two layers of plywood with Formica top and bottom on the permanent one.
But for now I am just using this one and keeping notes on what I like and dislike. I didn't get to do much over the summer, to much up and down with the back. Maybe this spring…....Maybe I can get David to sell his place in NM and move in….Yeah that's the ticket….
