Project Information
This is another new design, I hand crafted this box Ladies Jewelry and or gentlemen's box from spalted hackberry, this box offers hidden hinges, ( my first hidden hinge box) a pull out tray and a hidden compartment under the tray which is opened by way of a key, the lift out tray is the key. To open the false bottom door, The tray has embedded magnets on the under side and normally sits so that the magnets are facing the back of the box, the false bottom door magnets are also embedded in the wood on the bottom side which is facing the front of the box, once you lift out the tray then you spin it 180 degrees and place it back in the box, when you do that it lines the magnets up with each other allowing it to automatically latch onto the false bottom door then you lift out the tray it also lifts out the false bottom door by way of using rare earth magnets. It measures 8" W x 4" H x 4 ½" D
