Project Information
H 50 cm
The sculpture composed of 3 figurines
Which can be treated as three characters
For example:Father Mother and Son.
The end of each figurine is made so that it can easily be inserted into any of the holes or pulled out of it.
Inside the hole you can easily rotate the figurine.
This array enables a large number of possibilities for placing the three sculptures, ie Manual kinetics.
For example, the sculptures can be placed in a horizontal, diagonal, triangular or other array.
At each position you can change places between them And rotate each one at any angle.
The surface on which they are placed includes 3 rows of equal holes, 2 on the edges and one in the middle,
Each column contains 5 holes at equal distances
Gallery
Comments
yes they are tree roots
