Showcase cover image for mobile solar kilns
Project Information
I'm not sure if this qualifies as a wood project but I am almost as proud of this cobbled up kiln as I am of anything else I have built. Finding wood is a big part of the fun and taking advantage of an opportunity like this is great.
The tree feller we met in Pennsylvania called and wanted to know if we could use some more wood. He was bringing his horse trailer empty to Montana just north of where I live and would cut some trees and have them sawed for us if we wanted. We snapped it up. Of course the wood was green so we had to concoct a way to dry it and we built these two "solar" kilns. The only space available at the time was on these two unused trailers. We offloaded the wood and stickered it up and painted the ends.
The first kiln was built on a flat deck car hauler using the stake pockets to build a 2×4 frame. The smaller kiln was built on a golf cart trailer with a frame attached to the deck. Both were covered with greenhouse grade plastic and fitted with thermostat controlled fans. The beauty of using the trailers is that when winter came they were both simply rolled under the shed roof. The wood dried beautifully over the summer and was all less than 10 percent by winter.
Gallery
Comments
We love your ingenious idea! How about towing it over here for us to use for a while?!? LOL
L/W
That is such a brilliant idea! Clewer.
Wonder if a unused greenhouse coud do the same trick? (would need to mind not breaking the glass though..)
That is a great idea!
I will be using it.
That is awesome. Great job and welcome to LJs
"The tree feller wanted to know if we could use some more wood"
"Um, No thanks, I think I have enough lumber" Said no wood worker ever. Nice build.
Good thinking - it's a good feeling getting your own wood ready. I can see from your projects it will be put to good use. Well done.
Nice, save labour loading, and then moving the load into the maximum sun, you are one smart cookie!
Brilliant.
Now how are you getting wood from PA? I'm in MT.
Thanks for the kind comments.
To lightladylefty, yes I will haul it over if you will take me fishing.
To kaerlighedsbamsen, a greenhouse would work absolutely as long as you have good air circulation and venting to let out the "wet" air. We have a little greenhouse that is too small to put wood in but it gets really hot in there which is good for drying.
Great concept!
