Project Information
Mobile Drill Guide Stand.
Many times I had the need to drill vertical holes with a drill bit, a forstner bit or a holesaw that the surface did not fit on my drill press.
At first I designed a vertical drill guide stand based on dovetail slides, but been able to find a 30cm drawer guide that had no play I decided that this was a better and easier way to go.
I borrow the chunk with its axel from an old broken drill that I had and with two 12mm ID bearings and some scrap 2X4 and marine plywood I build this mobile drill guide.
With this drill guide, you can make perfect vertical holes on any flat surface every time.
Hope you find this guide useful as I did
thanx Stelios Stavrinides (AKA Steliart)
Gallery
Comments
Good idea and great design. I like the use of bearings to align and support the lower chuck. Clever !
Best,
Serge
Bricofleur - Serge
Thank you buddy !!!
Brilliant idea Stelios! I can see how this could be very handy to have in the shop!
woodshaver (Tony)
Thank you Tony,... actually I like this better than the factory drill guides they sell over here which are not stable enough and also not so acurate
Very spiffy steliart. As Serge said, I too agree about the bearings, and I'll add the drawer slide as another nice addition. Well thought out.
Nice joband creative idea with the drawer slide.
Roger
Thank you very much
doubleDD
Thank you Dave !!!
Looks like a good adapter and very useful in many situations when things just won't fit on the drill press .
I wonder if you could not add a lever and mount for the drill like a drill press ?
Klaus
Looks better than the store bought versions, great job Stelios!
kiefer - Klaus
Thank you Klaus. This was a minimalistic hand drill guide design but yes with some changes, stronger sides, a spring, maybe two slides and a few more things it can be turned into a mobile drill press… even though it will be more heavy I think and you will have to mount the drill every time… Just thinking out loud here… but definitely possible I believe !!!
waho6o9
That was the reason I build this my friend, because I did not like store versions I found here…!
Thank you
Very cheap, simple and efficient method. I have some industrial made thing which doesn't please me. Good idea on this.
majuvla - Ivan
Thank you Ivan. Exactly the reason for this build !
Great solution.
tyvekboy
Thank you :)
Hello Steliart
A very nice idea
My mind is in reflexion to do the same jig for my bosch GKF 600 to make repetitive holes for a marble game
I must add a stop block to have the same depth …
Parkside tools are very interesting for a very small price. I like them
My mind become very hot !!
Thanks for sharing
Diggerjacks
Thank you, it's easy to add a stop block at the side, didn't put one myself as I did not need it yet but eventually I will. Would love to see your version too. As for the drill I think its the best at its price tag.
CFrye Candy
Thanks Candy, yes and it does come handy when you need a straight hole on a large surface :)
