Showcase cover image for Mobile Base for Drill Press
Project Information
This is a simple mobile base that is really stable when moving around and rock solid when the base is down on the ground. When in use the wheels are like outriggers that give great side to side stability.
I used Rockler's workbench wheels and dimension lumber from the shop.
Imitation is the highest form of flattery, so a shoutout to Rob Drown for his design which I found here on the Lumberjocks site.
Gallery
Comments
Simple and effective just like it should be.
You improved my design, good for you. I hope others benefit from your creativity. I have certainly used ideas form the folks on LJ. Thanks for the recognition. You made my day.
I have that same set up on my outfeed/assembly table. I never thought about using it on my DP.
Thanks for the idea.
