Project Information
I just built this sled for moulding in some raised panel doors we are doing.
I added an insert to bevel the miter. It is removable using threaded inserts in the sled. It is a piece beveled at
7 degrees. This allows the moulding to set flat on the bevel of the raised panel. You can remove the pieces to do normal flat miters, or change pieces to a different bevel.
The fence is bolted to threaded inserts to allow for adjustment or replacement.
Baltic Birch plywood with Mahogany. Scraps were glued to create thicker pieces.
One coat of Tung oil finish
Enjoy
Gallery
Comments
· Registered
Looks very functional, Kent, and the results speak for themselves.
· Registered
Kent! Are you well? No maple and walnut? A plain shop jig? I'll grab my doctor Buddy and be right there. Rand
· Registered
I like the screw-down adjustment for the fence. I built one with the fence screwed down permanently after very careful measuring and clamping. It is off by just a hair, but it's annoying enough. I may have a date with some T-nuts tonight to fix that.
Good work!
· Registered
Nice sled… Good job!
Do you cut all your Right Cuts first then your Left Cuts with stop blocks?
I made one not too long ago from a scrap piece of particle board and a large 45 triangle I made from a plastic drafting 45. Works great… Looks very similar to yours.
· Registered
Nice work kent another winner
· Registered
Kent, that looks like a very well built sled. It's also nice looking. Good work!
· Registered
Very nice sled Kent. I like the idea of the bevel strips to get the trim to lay flat on the panel.
· Registered
If the miter sled is good the work is good
The pictures show the perfect result
I like it
Two piece in one a miter sled and a cross cut sled
A good idea
Thanks for sharing and beautiful work
· In Loving Memory
Very nice Kent.
· Registered
A little Bubinga would have spiced it up a little although the utilitarian look is good too.
· Registered
Whoa guys, give me a break. You make it sound like mahogany is some cheap undesirable junk wood.
I had no idea what I started by using Bubinga on some of my jigs. I guess next you will expect me to build jigs with Ebony, or maybe some real elephant Ivory!--LOL
I guess I asked for all those comments-huh?
Aside from that, thanks for the other kind remarks
Kent
· Registered
Another jig of yours added to my favorites , Kent : ) Thank you for sharing !
· Registered
That jig speaks volumes about the quality work it produces. (I would like to make one) maybe I will. thanks for a great post.
· Registered
Kent: A great looking jig. I like the use of some great looking Mahogany.
I need to make a jig like this.
· Registered
Another impressive jig Kent! Thanks for sharing.
· Registered
Nice job Kent! I like that it converts back to a normal sled might have to make one. Thx for the idea!
· Registered
Very nicely made and multi functional too.
Good work.
