Comments
Very nice looking bowl, been really enjoying the use of aneline dyes I've seen on LJ's and tried myself also.
Did you take any "before" pictures ? Nice shape .
Beautiful turning and use of color.
Hey Dale
Nice turning great job looks wonderful
wow, that looks good
"Start to finish turned and dried on the lathe".
how do you dry it while still on the lathe?
If you take the wall thickness to a uniform 3/8ths or less and run the lathe speed around 1800 the moisture will be forced to the out side by gravity. Sand from the inside first the heat and the rotation will dry the wood. Be careful how much heat you generate so you limit any surface checking.
Sorry no before pictures.
Dale, great job…I like the design and the use of dyes.
thanks for your your response
i will have to try that sometime
