Project Information
A friend asked if I could build him a map cabinet. I had no idea what a map cabinet was at the time. After some research we agreed on a design and I got started. Here is the finished result. It is made from quartersawn white oak and white oak plywood (expensive stuff!). It's big and heavy measuring about 40" wide and 29" deep. The eight drawers are made from poplar, are 3" high and slide smoothly on wood runners. He plans to use it to store his art and poster collection. I'm pleased with how this project turned out!
Gallery
Comments
Simply Beautiful.
Great job.
That turned out beautifully. I remember your question on the drawer slides. I see you went with runners, which is traditional and in line with the nice dovetails you cut. Excellent from top to bottom!
Good memory Bill! I was worried with as big as the drawers were that they would bind on runners. But I'm glad to say they ended up working well. And a little wax helps too!
Very good looking cabinet Dave.
Saw 'map cabinet' and had to take a look. I worked for the Corps of Engineers for 40+ and filed many a map and drawing. Would have loved to have had storage as sweet as this. Very nice job. On my latest workbench built for my daughter I used similar handles. I prefer this style for workbench and for cabinets, no rough edges. I can believe that cabinet weighed a tad. ha. The cabinet portion of my workbench ( 3/4" oak plywood ), due to tight fit and weight, I borrowed a neighbors floor jack to help us slide it into place. I really like the drawer slide design, very compact and gives user full use of 3" drawers. Nice finish too. Curious of the brand of stain you chose. Nice show piece for maps and art.
Hi Jim- I used a several step process for the finish to try to bring out the ray flecks in the oak. Started with amber transtint, followed by Sealcoat, then General Finishes Georgian Cherry gel stain and finally 3 coats of satin Arm-R-Seal. Thanks for the kind words!
I've come to love all the General Finishes products. I used their Georgian Cherry gel stain on at least one. Curious if you used any of Charles Neil's Pre-Color Conditioner on the Oak Plywood ends. Looking at the cabinet, you may not of had any ends of plywood showing. The Gel Stain was not water based correct. I had mixed feelings the one time I used CN's Conditioner prior to a water based stain. You have to be real careful not to remove everything. Not blaming the CN product at all, it's the user and possibly the water based stain combination. I'm far from real experienced. Prior to an oil base stain, I've seen how well it can work.
Jim- I tried the CN conditioner on a sample piece and didn't see much of a difference like I have on past projects. I was more concerned about a difference between the hardwood and the plywood than about blotching. Since I didn't have enough to do the whole cabinet I did not use it this time. The gel stain is oil-based. And I agree with you about the GF products. I've been using them almost exclusively lately.
Awesome map cabinet! As a map collector and former land surveyor, I definitely see the need for one of these.
Very nice piece. I like the Cherry stain on the White Oak.
Is the plywood on the ends panels only?
This is a wonderful piece and you have done a beautiful job on it. This could also be a spool chest or a fine tool chest for carving tools or what have you. It's very nicely done.
helluvawreck aka Charles
Fantastic! Absolutely stunning. It's sure to become a treasured heirloom piece.
Beautiful chest, great craftsmanship. Very inspiring. Hat's off !
Best,
Serge
Excellent workmanship!
I always liked the look of these cabinets, you made one with true elegance.
That is most excellent! You should be very proud of your work.
Beautiful map cabinet!!
