Project Information
Similar to Jay Bates version, but I attached verticle supporst every other stud, 32" spacing…. no regrets.
On right side I doubled up 2×4 verticlts so I could easily store 8ft material - ply or 2×4's wouldn't fit if I didn' t double up one side.
Lesson learned" the pipe is.84", and I drilled my holes with a 0.875" spade bit on drill press at 1deg angle… I end up level w/ 1 degree but I'd increase the angle = experiment, maybe 4 degree or so.
use a carbide blade in sawzaw and each cut is only 30 seconds on black pipe. Space out so in vice so you rest against vice, instead of freehanding it w/ sawsawz.
Gallery
Comments
Nice Rack!
