Comments
It's amazing what happens with patients and wood.
Great job on the truck. Hope you post more of your work.
In Loving Memory
Great attention to detain. You do good werk.
That is a great looking truck. Great detail and realism.
Absolutely gorgeous log truck! Every detail is very well executed, looks like the real thing. Impressive work!
Anyone have a craftsman lathe duplicator this one I've used lots of times,the problem is the cutter will not cut the same size as the original.The original is is smaller ,the cutter bottoms out before the stock gets to size,I've checked the head pin with the duplicator pin both are plum also the tail pin all plum with each other. Don't know what the problem is any help would be greatly appreciated .
