Project Information
Wood And Materials Used
Big leaf maple, wenge, padauk, eastern white maple, eastern red cedar, purple heart, zebra wood, Oregon bitter cherry, blackwood and black walnut
Tools Used
Jointer, table router, plunge router, Dremel tool, chisels, clamps, 50" planer, air sander, belt sander, band saw, table saw, skill saw and Alaska chainsaw mill with 36" bar
Location
Northwestern Oregon
I mill most of the wood that I use for projects with an Alaska chainsaw mill (see two recent posts in the Wood & Lumber forum for more on that).
My brother is an avid birdwatcher and photographer, and three years ago he said that he wished I would build a live edge coffee table for him. I built the table for his 2020 Christmas present. For those who are not into details, I am posting photos of the finished table here at the top. For you detail folks, keep scrolling down. There may be a limit on how many photos one post can contain, so I will show this project in multiple parts.
I inlayed images of 34 different birds that are either native to Oregon, or migrate through here. The table is made of bigleaf maple (Acer macrophyllum; the largest maple native to Oregon). Often bigleaf maple has nice figured grain such as the "quilted" grain in the slabs that I used to make the table.
I used the following woods for inlays: Padauk, eastern white maple, eastern redcedar, wenge, purple heart, zebra wood, Oregon bitter cherry, and black walnut. The table is 54" long, 31" wide and 22" tall.
Here goes the build description from the start, with details:
My friend Alan and I milled this bigleaf maple on my property in 2018. I stacked and stickered it (with ends painted) and it air dried for three summers. The air dry rule-of-thumb of "one year per inch of thickness" works well. By the fall of 2020 it was cured and ready to use.
My planer is only 13" wide, but Creative Woodworking is a shop in Portland (an hour drive from where I live) where woodworkers can bring in their slabs to run through one of their 50" planers (the planers also can be set for sanding). At $75.00/hour you can plane a lot of slabs. Creative Woodworking also does resawing and they have all kinds of huge woodworking machines. We Oregon woodworkers are lucky to have access to a shop like this!
Here we are running the slabs through one of the two 50" planers
Back at my shop I routed the edges before gluing the two pieces of the top together
Next I used the table router to put grooves in the slabs for #2 biscuits before glue-up
Then glue and clamping overnight
After I had glued the top, legs and shelf together, I made another trip back to Creative Woodworking to run the pieces through the planer one more time. The top and legs are 2" thick and the shelf is 3/4" thick.
I used an auto body profile tool to mark the arches that I cut out of the bottom of each leg.
Double sided tape holds down a pattern for the mortises on the underside of the table top. The legs will fit into the mortises. I used a 3/4" bit with bearing and cut mortises 2: wide and 1 1/4" deep.
I inlayed two 1/4" thick (2" wide, 1" deep) steel C channels into the underside of the table to prevent warpage. The C channels are fastened to steel threaded inserts. I also inlayed four Oregon white oak ribs. This view also shows the mortises for the legs. Looking back on this, I think that the four white oak ribs was big time overkill. I won't do that on the table I am building now.
Next I cut 3/4" wide, 1 1/4" deep mortises into each leg. The shelf will fit into these mortises.
The mortises are done and its time to do a dry run fit up
It all fits together perfectly
I will continue with the inlaying in part 2 of this build thread.
Comments
· Premium Member
That's beautiful work. Looking forward to part 2 even though the piece is finished and posted ;) Nice write-up.
· Registered
Great write up and detailed progress, thanks for sharing that. Now that is a beautiful table, love the mixture of the birds that have been inlayed. Well done.
· Registered
the inlay work is awesome. Never used C channel to control warping. Curious if it works, because it seems you are preventing seasonal expansion and contraction.. Unless those screws are in slots.
· Registered
I hesitated to post photos of the finished project right at the top, but I realize that not everyone is into details like me. I didn't want to lose anyone that might not have wanted to wade through all of the steps to see the end result.
· Registered
There are a lot of folks that like to read about the details, it makes the projects come to life.
And welcome to LJ's
· Registered
Wow! I’m so impressed. Thank you for sharing this saga.
· Registered
Yes, the furniture bolts go through 1/2" long slots in the C-channels. The center furniture bolt is tight, but the outlying bolts are snug to allow for seasonal expansion. The finished coffee table has been in my brother's living room for almost two years with zero cracking, warping or other issues.
Being new to this site I don't know if inserting a link to another site is permissible. If you Google "Blacktail Studios" (located in Portland, Oregon) there is a tutorial on installing C-channels. I followed those instructions, but installing the oak ribs was my dumb idea... Blacktail Studios has a youtube channel with hundreds of high quality wordworking how-to videos. Cam, the owner is a full time professional table builder. He specializes in wood tables with epoxy ( epoxy filling large voids). I am not into epoxy tables but his site has very good table building tips.
· Banned
wow a fantastic table.love those inlays.great write up and pic's. thanks for sharing your beautiful work. cant wait for part two.
· Registered
Beautiful work OW... while biscuits do the trick, that job deserves Domino$$$$...
· Banned
· Banned
What is the advantage of dominos vs biscuits?
there much stronger if your doing mortise and tenon construction but for what you did the bisquits did fine for alignment purposes.but for strength probably minmal.
· Premium Member
Fabulous table and your inlays really set this off. This project is definitely going in my favorites. Thanks for taking the time to document and share your build process.
