The styles and rails are made from clear pine, and the pannels from hardboard. I wanted to use low cost materials because this was my first try at making a door and if i screwed up it wouldnt cost me much.
I also knew i was going to paint the doors so premium wood seemed like overkill.
I cut the styles and rails with my mitre saw.
I made 1/4 inch grooves on the table saw On all the stlys and rails. I used a piece of scrap to test cut the tongue. I measured the height of my blade to what i needed remove, roughly 1/4 per side. once i made a nice fitting tongue with my scrap piece i cut my stock. I glued and clamped all my pieces and checked for square with a framing square.
For the bead, I had purchased some molding from the lumber yard and cut and glued it in place.
