Project Information
I have wanted to add a leg vise to my bench for a long time. I received a Yost 18" vise screw as a gift for Christmas, and today I was able to get it installed. I have a Roubo build coming up, and figured if I could install a functional leg vise on an existing bench, then including it in the build process should be at least a little easier.
I cut down some 2×12s to 6" wide to fit on my jointer. After jointing and planing, I used my biscuit joiner and glued them back up. I laminated two 1 1/4" pieces at 10" wide. I ended up with a final width of 8 3/4" that tapers to 6" at the bottom. I also chamfered the top and bottom faces. I sanded to 220 grit and finished with boiled linseed oil
My bench legs aren't flush with the top so I planed a 4" wide piece of pine to flush everything up. Then, I used a corded hammer drill and Forstner bit to bore the hole in the leg to accommodate the vise screw. I bored the screw hole in the chop with my drill press.
I cut a large dowel to serve as the crank for the vise. I also drilled holes in the screw so that the dowel is stationary and doesn't slide back and forth.
As I am starting my new bench build in the next month, I have been looking into the usual accessories. The Benchcrafted stuff is incredible. I ordered their plans for the Split Top Roubo, but I am struggling with the price associated with their hardware. I have absolutely no doubt regarding the quality of their Hardware, but am finding it difficult to convince myself to drop $700 on vises.
In the end, I am pleased with this vise screw, and know that it will only be better when installed as part of the build. I was impressed enough with the quality of the screw that I decided to order the Yost 17" end vise. I will report on that when I install it on my new bench.
Thanks for looking!
Gallery
Comments
NIce leg vise. I like the racing stripes of the quarter sawn SYP.
Nice leg vise, but no parallel guide?
I'm in the process of building a roubo bench. Check out the face and tale vices built by Shipwright. They use wedges. I have seen them first hand and they work great and cost n a few bucks to make.
- Smitty_Cabinetshop
Smitty, I am going to include the standard through leg guide on my upcoming bench build.
Very nice legvise!
Youy don't need a parallel guide. Instead, have a look on Youtube. Hay Bates uses a wedge on the bottom and cut out a coresponding noth at the bottom of tghe vise. A very simmple and effective system to prevent racking!
muesli, a parallel guide doesn't prevent racking. Not that racking is a huge issue on leg vises. It's to keep the jaws parallel with the edge of the bench top. Maybe you'd call that 'vertical racking,' and that's why the need for a wedge?
Anyway, I'm amused at the numbers of ways there are to get around simply setting a pin at the base of a leg vise. It's so easy, even a cave man can do it. But there's criss crosses, wedges, chain drives, etc. (all at their own $ figure) out there to eliminate the simple requirement to pull and re-insert a pin. It's not even needed that often at my bench.
I like this a lot… still trying to figure out how to thread a 2.5 - 3 inch wood screw (and tap a leg) without spending $2000 on a kit. I want to make a leg vise when I get around to my Roubo bench. I have a Moxon vise I built with 1 inch wooden screws but I want something more substantial. I may give up and do what you did…
Well, you did a good job in the vice, well done
Yep… you did it right… a thick chop is mandatory (IMO). I cringe when I see thin chops…
