Project Information
Was in need of replacing an old table that was made up of some compressed wood covered in formica. Table was made from a 13 foot 8/4 slab of cherry wood. The top was glued up from several pieces that were milled from the slab. The legs were ruff cut on the bandsaw then shaped on the router table with jig. Base was assembled with loose mortise and tenon joinery. The apron and stretchers were cut with a slight bottom arc to them and accented with a thin strip of Gaboon ebony to form an 1/8" reveal. I also curved the ends of the top with with a router. The finish was 5 coats of General Finishes Arm-R-Seal with final coat buffed with #0000 steel wool and Renaissance wax.This was my first attempt at constructing a Kitchen table. I wanted something that was a simple but elegant. Next feat would be making some chairs to go with the table.
Gallery
Comments
Great job on the table and good luck with the chairs!
Beautiful, nice design, is this your own design ? Great finish also.
Nice looking table and the Cherry grain looks great. Was the top resawed into 1" planks. The top also seems to have a slight curve on the ends. Is that just an optical illusion? How wide did you make the apron? Has the color aged much since it was last sanded?
The design for the table can from different pics I've seen of some tables.
The top was resawn to final 7/8" and edged glued about 8 pieces. The table is about 40"x48" if I recall. The top was curved with a router. I made the aprons 4" wide with 3/8" arc the distance of the pieces. The color has slightly gotten darker, the table is only a few months old. I guess it will get nice with age.
"I guess it will get nice with age."
Correction: "I guess it will get nicer with age."
I like the way this all came together, Page. I think you nailed it - simple and elegant indeed. You've achieved a delicate look without the table looking fragile. I really like the use of arcs and the tapered legs with a gentle curve are two design features that I don't believe I've seen combined.
Well done.
WOW Page, that is gorgous…I'm going to build a dining table for my wife and I…as soon as I finish the other 3 or 4 projects I'm working on…from what I understand, that's woodworking
Beautiful Table. Been doing this long?
a gorgeous table - something to be treasured.
Thanks for the compliments guy /gals.
Michael, as for how long I've been doing this; This was my 4th completed project. I've only had my equipment for about a year. Time is the key, never have enough of it.
extremely nice table.
beautiful project.
looking forward to seeing more of your work.
That is one fine table. I like the combined accent of the curved apron with the ebony highlight.
B E A U TIFUL!!!!
