Project Information
This project was inspired by rivergirl's project ( http://lumberjocks.com/projects/37400 ) of a desktop shelf with storage space. I've seen other window plant shelves like this, so I made this one in about 30 minutes Sunday morning as a housewarming gift for a young lady who just moved in to her new home. You've heard the expression, "Measure twice and cut once…" Well, I only measured once. I measured how wide the legs had to be to clear the sink, then I planed a walnut board that was just slightly too narrow to make a gunstock from and squared the edges. Next I cut it a few inches longer than the width of the legs, and cut 2 - 2" sections of the scrap to make the bases. Then I ripped 4 - 3/4" pieces long enough to clear everyting at the sink and to keep the shelf as close to the window ledge as possible. To make the mortises I measured the base 1" from the thin edge and marked a center place to drill a hole. Ditto for the other side. Next I put a fence on my drill press with a stop to center the first hole. Then no more measureing. I drilled all the holes. Then I put two dowel center finders in the holes and pressed them into the shelf on each end abut 1 1/2" inches from the ends. Then I used a forster bit to drill a 1/2" hole at each dimple. Now, I've got 3/4" square legs and 1/2" round holes to match up. Nope, to lazy to chop out the mortises, I have a jig for my router table that is U shaped with a 3/4" hole in each upright to allow a 3/4" square spindle to turn. Using a straight bit, with a stop to set the length of the tenion, I raised the bit up till I had a tenion just under 1/2" that was a friction fit to the hole in the shelf. It just took seconds to put 7 other tenions on the spndles. I rounded all the edges using a 1/4" radius bit then used an ogee bit to make a decorative edge on the shelf. Total time not including time for the glue to set… 30 minutes. While I was set up I could (and should) have cut out 10 other shelves but I didn't have the wood planed and ready. A coat of tung oil and some spar varnish to keep the moisture from watering plants from damaging the shelf and it was ready to give as a gift. Christmas is coming, guess what I'm going to give this year…
