Project Information
The old kitchen was built in place painted white cabinets. When I bought my current home I knew they were going to go. I then got the silly idea to remodel the kitchen myself. I did most of the work myself. The only parts I subbed out were the counter tops and moving a gas line.
The cabinets are build out of cherry veneered plywood with the exception of the face frames and doors. I used solid cherry for those. I also did the coffered ceiling and the barn door. I will post a separate project for the door. This was my first time laying out a room /project in a CAD program. It was a must to get all the sizes and openings right. LED lights built into the tops and bottoms of the upper cabinets. I will tell you one thing. Sanding all the door and drawer rails and stiles tried my patience.
Gallery
Comments
I've never seen anyone tile all the way up the wall like that (not sure if I like it or not…) but the cupboards are outstanding and I will be visiting the barn door post as soon as you get it posted!
I have a project similar to this with built-in cabinets in the kitchen in my store but I may have to tear them out to do the new electrical and insulation, making it a moot point. I do have a 3-spindle shaper headed my way at some point so am already looking for projects that will allow me to practice on my own needs before I reach out to the public.
Thanks for sharing!
Premium Member
nice kitchen remodel,looks great but as mike said ive never seen tile done like that before,maybe a little too much.otherwise i like what i see,those pull outs on the side of the stove,great idea.
Premium Member
that has a modern country look - I like all of it
Nice kitchen remodeling. I also like the pull outs on either side of stove. Great Idea.
Looks fantastic. Nice work.
You have to feel enormous satisfaction completing such a stunning kitchen yourself! Thanks for sharing.
L/W
WOW…THAT'S COLOSAL!
I know, right? And even then you'll make mistakes…
Oh. My. Yes. Tedious in the extreme. It's why so many companies spend a lot of money on wide belt sanders and rotary denibbers. And robots.
Great project! Very well done.
Very nice work! I'm sure there's a great deal of satisfaction bringing that to completion and being able to admire your own handiwork every day.
While I feel you on sanding, I'll give you my process and you can take it or leave it.
First I plane to just one or two hundredths oversize. Familiarity with my planer means that batches done at different times come out precisely the same thickness.
Second, I edge sand on a stationary oscillating belt sander, but that's the only sanding I do on the rails and stiles before assembly.
I sand panels to finished smoothness before assembly.
I mill the rail and stile material, cope the rails and assemble the doors. But here's the key, in my mind: I spend as much time as it takes on scrap material to ensure that the rails and stiles are precisely flush. However long it takes it will never be as long as sanding smooth mismatched rails and stiles. I keep a set of samples that I work from to dial in the router precisely. I also have the luxury of two router tables, so I can leave them both set up, one for routing the profile, the other for coping the rails.
If I've been meticulous with the router setups, I can sand the faces of the door frames with two passes with a ROS, once with 100 grit to ensure absolute smoothness of the joints, and a second with 150 grit to bring it to finished smoothness. That assumes spraying lacquer. For other finishes, you'll probably want to take it to 220.
A little edge sanding on the top and bottom, some roundovers/chamfers on the edges, and they're ready for the spray booth.
Like I said, I hate sanding as much as anyone, so I've tailored my process to keep it to a minimum
Anyway, take it for what it's worth.
Nice job and congratulations on your 'Daily Top 3' award.
