Project Information
UPDATE
CORRECTION ON THE ANGLE
Please forgive me. I made a mistake on the angle of the blade set.
The angle is not 40 degrees it's 45.
I made the change below also.
Sorry, I hope this didn't mess anyone up!
Credit goes to Dusty & Bsmith .. Thanks guys for finding that mistake!
It's not fancy like the Deulen $50 dollar Knife Sharpening Jig but it works!
Link to my new more fancy one > http://lumberjocks.com/projects/70562
The blank is 2 1/2" X 1 3/4" H X 4 3/4" I made two 45 degree cuts in the 2 1/2" side, made 4 set screws and tapped the wood to except the set screws.
Note….You can make the jig a little taller for a better grip in needed. Maybe 2" instead of 1 3/4" H
I gave the kinives 10 strokes on each of 220-, 320- and 400 sandpaper then once on the 400 laying flat to clean the edge. I made this as a trial experiment and now I will make one using some Ash or or some another hard wood. I use my table saw for the flat surface. I have some tempered glass that I will use next time!
Thank for peeking in!
UPDATE
UPDATE
