Project Information
Saw this in an old American Woodworker magazine and modified it to fit my jointer. It only lifts the jointer 1" off the ground.
Nothing but 2×4's and 3/4" plywood. There are a couple 3/8" dowels on each side and each "foot" is attached with a 3 1/2" x 3/8" lag bolt (I used a 3" lag bolt and countersunk the head). The interior dimensions are based on the footprint of your jointer, and you may not need or even use the center brace if you have a square cabinet jointer. I threw the whole thing together in about an hour using glue and 2 1/2" wood screws.
Here I assembled the frame. The height of the 2×4"s is determined by the total height of your casters minus 1". The casters I used were 3 3/4" so I cut down the 2×4's to 2 3/4".
Here I attached the bottom piece of plywood and the top side pieces.
I then attached the casters. 2 fixed casters and 1 locking swivel caster. Got all three at Harbor Freight for less than $10 (the fixed casters were on sale for $1.99 and the swivels was $3.99).
I thought about just using the locking caster to hold it in place but it moved too much so I went ahead and added the "feet". The feet are cut down to 2" and then 45 degree bevels are cut on all corners. I didn't like the way they set when the feet were down so I took the belt sander and flattened the end that touched the floor to sit flat.
Borrow the neighbor to lift the jointer and I'm done.
If you are interested in my Sketchup files (which you would need to modify to fit your jointer) you can get them here:
https://1drv.ms/f/s!Ak3MNCPBmYglgQoSsJIcD3pRbAl8
A great little project and now it is much easier to get my jointer out for use.
Gallery
Comments
I have an old metal table that my 4" jointer and 6" belt sander are mounted to. The wheels I mounted under the table make it very unstable. I just found the way to stabilize it!
Very Nice!
I've got the same jointer… this could come in handy.
thanks for sharing!
I have Ridgid jointer exactly like yours. How well does your reducer work on taking care of dust & etc. and what kind of vacuum device do you use for control? bbqKing
Great idea. I like shop made mobile bases. Happy with that jointer? What kind of thickness planer ya got?
That is a great stand. I was thinking about getting this jointer either used or as a refurb (preferable if I can find it). I'd love to hear your thoughts on it too. Same wit you bbqking. This would be my most expensive tool so Its a tough choice to make. If I built this stand, which looks way affordable, I could fit this thing anywhere I want in my garage with no trouble. nice work
OK, I like this a lot. Thanks for sharing how you did it!
I am going to have to make one of those soon, you can't really move that thing around without one, at least not by yourself. Thanks for sharing.
In Loving Memory
Well done & thought out Greg.
BBQKING - I just use a Craftsman shop vac with that reducer and it really does eliminate most of the wood chips. That Ridgid has very efficient dust collection. I just have some light sawdust under the table when I'm done.
WOODSPAR, HOOKIEMOJO - I'm very pleased with the performance of the jointer. Got it used off Craigslist from a guy in Kentucky. I'm not sure how I did without one of these. I now cut all my wood slightly oversize and use the jointer to smooth the edges and remove any burn marks where I make a bad cut. I've used it as a planer as well, but it is not very good for that as you tend to not get parallel flat faces since the slightest edge variance will throw it off. I don't have a planer yet, but that's my next purchase (probably a Dewalt 735).
Outstanding. I don't have a jointer yet, but its on my list. I think I can modify this for other tools though. Thanks for sharing!!
I llike your design. Good work. You can't go wrong with the DeWalt DW735. Got one and love it.
Greg:
Thanks for a great post…..I may be dumb, but how do you get the base off the wheels and non-mobile ??
I am assuming the two vertical 2×4's on the front lift the base up and down but I can't figure out how
you make it sit flat and not move… would appreciate you enlightning this old man. Thanks.
RWR - Yes, the 2×4 "feet" lift the end off the ground and support the stand. The stand is still on the other two fixed wheels, but it doesn't move with the 2×4's down. The original article I read had swivel wheels everywhere, but I'd be afraid the two wheels on the ground would shift left or right.
Also, the jointer isn't perfectly flat when the feet are down, but at a very slight downward angle. It doesn't affect using the machine, though, since all the jointer needs is for the two tables to be level with each other.
How do you like the jointer? I've thought about that model as well.
USCJeff - I'm pleased with the jointer. It is smooth, the dust collection is good, an dthe knives are easy to change with jack screws for alignment.
AWESOME!
I was looking for some homemade mobile base for my jointer, and drill press, and will use this design to set something up- I really like the simplicity and functionality of this base.
thanx for sharing!
Great job done and great idea Greg. I own the same jointer. Love using mine. I just took the feet off and replaced with wheels. I bet your design is much more stable. With a wide base moble plans. Great job Atta Boy !!!!!!
Very nice base. Great construction.
