Project Information
Story: Some of you may recall a project I posted a short while ago of nesting bowls these bowls came from Live Oak, There wasn't much difference that I could tell between the post oak and the live oak other then the color, the live oak seemed easier to work as this post oak has a lot of splinters that like to stick out in different places, This is just one of many post oak logs among the live oak that I have in my collection, I got all of the post oak logs from a neighbor that had one cut down from his yard, this log I worked while it was still green and had to do a lot of repair work on all of the splitting and cracks.
Build: This was a rascal to make due to all the work that had to be done with filling in all of the cracks and splitting, I first cut the bottom and then the top before cutting out the inside, the plug that came out I made a tray out of, sanded all parts to smooth, glued the bottom on and the final part was gluing the lip onto the bottom of the lid. Measurements are 8" x 6" x 4 1/2" finished in a single coat of tung oil and several coats of my one mix wipe on poly.
Thanks for looking and comments are always enjoyed.
Gallery
Comments
Very cool box!
Nice. The lift out tray is a cool addition.
Very organic design, especially the tray. I'm curious how one goes about cutting out that plug.
Randy, I really like this. It is natural and has a utility to it seldom seen in such pieces. The tray is an excellent innovation and makes this worth much more as a sales item. These should go well if you put them out. Don't be bashful about raising the price on these.
I put a comment on your band clamp forum piece.
Keep boxing and keep posting.
This is really cool. I love the look.
Thanks everyone.
David once the top and bottom are sliced off, there's an entry point into the side of the log from the blade I cut leaving a 3/8" wall around the outside thus the plug is cut out. I'm just do it very well so that you can't see the entry point.
Hey Randy, If you start with a bark on log, the outer "shell" with the bark on makes really cool birdhouses for little guys like wrens. I hang these under the eves of my shop and I'm amazed how quick those little wrens move in. I just glue/brad nail a piece of scrap to the top and bottom and drill an entrance hole.
Andy, you're going to have to show me a picture of what you are talking about, normally after the cut the outer shell falls apart.
Banned
That is an amazing box you have created Randy. So much creativeness with a bandsaw and a log.
Excelent, Randy. I like everything about it.
Cool box…off the beaten path so to speak. I have several oak rounds on the wood pile. Think I will give one of these guys a shot. Also, you can free hand this box to the desired shape/depth, etc.
Thank you very much for sharing the photo.
Randy, It's too cold and wet to take a pic now but I think I must cut a thicker "shell" that includes all the sapwood cause mine just looks like a 5/8" thick walled tube (if that makes any sense). It looks a lot like your jewelry box (only with the bark on!). Birds seem to like the bark.
Is it possible to get a picture of the underside of the lid? What did you use to keep the lid in-place/from sliding off?
Thanks much.
Hi Ed
Once the lid and the bottom have been cut away and the inside core has been cut, Note: I always mark the top and bottom so I know which end I'm working with, I then slice off a 1/4" piece from the top of the inner core that I just cut out and mark the side to be glued, that piece becomes the lid lip to hold it in place.
Nice one, Randy!!!!!!!As usual!!...................Jim
Hi Ed
Once the lid and the bottom have been cut away…...................
Randy,
Thanks…..got it.
