Project Information
One of the projects I'm working on at the moment is a ladle. As I'm new to spoon-carving, I don't have a great feel for how thick something is as I'm carving it. So I decided I'd make a quick set of calipers so I can check my work as I go.
I started with a scrap of ipe, about 8" long, by an inch wide by 1/8" thick. I cut it in two, then cut a C shape in both pieces at once with a turning saw, then smoothed the edges with a spokeshave, knife, and file. Drilled a little hole in the ends, and put in a finish nail that I had annealed, cut it off with a pair of diagonal cutters, and then riveted the ends of it over.
A little sanding, a dip in the linseed oil, and I'm ready to measure thicknesses.
Gallery
Comments
Thats a cool, handy little project, Dave. I like them.
Sweet caliper!
Handmade tools rock and you sure have an inclination for them.
Nice addition to your hand tools.
Jon
Nice work, these definatly will be handy on your projects.
Premium Member
Thanks, guys! I was merrily carving away on my ladle, and realized, "Hey, I have NO idea how much wood I have left!"
So it was time to make these. And I used up a scrap, leaving only pieces too small to save!
Nice calipers Dave!
Premium Member
Thanks, Duck! Not bad for a little over an hour of puttering around. Still got a few boxes to unpack, but the shop is pretty dang workable already.
Nice set Dave. This is something I have meant to make for a long time.
Premium Member
Thanks! Pretty quick and easy, Jeff. Just a matter of getting a round tuit.
That's a good idea Dave. I use them quite a bit. Always handy for those special projects. Nice job.
Premium Member
Thanks, Dave! Also a good use of a "scrap" that's been rattling around my shop since I made the ipe spokeshave for the last swap. Hardest part was getting the surfaces planed smooth with the block plane.
Handy Dave!
Premium Member
Thanks, Kenny. I used them quite a bit yesterday afternoon as I was getting closer to done carving the bowl of the ladle. Lots easier than reaching in there with my big paws.
Premium Member
no sense buying a tool when you can have the satisfaction (and skill) of making it - good job Dave
Premium Member
Thanks, Dick! I figured you'd appreciate using a scrap to make a tool.
