Showcase cover image for I get hung up on clocks
Project Information
Here are some of the steps I wandered through for a different clock. I use store bought carving pieces to start my thoughts then trace around some parts of those carvings and sometimes adding a curve here and there to get them long enough or shorter to connect the lines. The carvings are only 1/4" thick or less and I start with 1" thick wood to carve. The fourth picture is what I decided the clock to look like but you can see the one I ended up with is only close to what is started out looking. I made the dial from a picture I got off google or somewhere then scrollsawed it out. When buying the clock movement one has to remember how thick the wood is counting the dial so I can buy the right movement.
The wood is hard maple, takes longer to carve but I only use electric and air grinders and no hand chisels. I'm lazy.
I always spray lacquer for the finish. And I am still using printers ink for the colors and a little glitter here and there.
I'll try to answer any questions you might have.
Gallery
Comments
Pretty amaizing clock and scroll saw work is magnificant. It looks old with this choice of colours.
Nice job carving the pieces!
This Beautiful! Your work is Very Nice!!
