Project Information
This piece of bog oak had to be treated with some wood hardner before the letters could be cut out,
it sits at the entrance of a house with a spot light shining across the face of it at night,and looks very well with the letters standing out.
cleaned the wood with a router to give me a flat face to work with and then removed area around the letters.
finished with teak oil.
Gallery
Comments
Great looking sign. I like the box you used to flatten the oak. great ingenuity. Well done.
I also agree - great looking and very original.
I like it!! I like the idea of using a bigger piece of wood than just a board and how the letters are raised. I have a cheap craftsman kit that I have used a few times, but your way looks much better.
Good job.
Now that is something you won't see everyday. Good job.
I really like that technique for flattening a surface with the router. Might have to keep that one in my back pocket.
Great job
Really nice work.
Just curious why you used teak oil.
It's one of my favorite finishes for bringing out the grain, but I didn't think it was good for exterior use….gotta reread the can I guess.
Thanks for your question Pete. Apart from "it's what I had at the time". Teak oil is deeply penetrating and repells water as this wood is open and cracked it protects it from getting further damage. The bog oak could be near two thousand years old. Recoated often it is still looking well.
Hi nice work , i also have a slab of bog oak that looks brown, as in your pic before treatment and finish . did the hardener make it more black looking ? also what hardener did you use? the stuff i have seems quiet soft like pine would the hardner really make it as hard as the jet black oak ?
Hi scottishbob, the hardener was got in B&Q and is Ronseal brand, it really needs to soak in well so give it plenty of coats.
That allows the wood to be worked with, this piece was very brittle before I started work.
The teak oil darkened the wood after all work was complete, but use plenty of oil and recoat often.
thanks and lets me know how you get on.
