Project Information
Oct 17/09
(First: sorry about the photo quality. Early morning and I guess my eyes were still blurry. I'll try again later for better pix)
Earlier this year, Karson so kindly sent me some wood to make some pens. Amongst the treasures was a piece of Desert Ironwood. I had enough for three pens. The first one is seen here:
The second piece was a big "oops" in the drill press. (Sorry wood).
The third piece was a big "oops" on the lathe and a chunk came off the one end. At first I was disappointed that I had messed up the blank. Then I was frustrated at the difficulties I was having with the pen-turning process. And then .. I remembered that this was very special wood and to waste it was just wrong. I just had to honour the wood by trying to salvage the pen.
I didn't know how to save this other than to throw some wood filler in it and so that is what I did. Afraid of a second failure with this beautiful piece of wood, the blank has sat on the shelf since July. But yesterday, I bit the bullet, and put the blank back on the lathe.
As the pen blank was originally turned and ready for sanding, I just had to start at this step, with the fix job.
I sanded it, put some stain on the wood filler (hoping that it would help it blend in with the pen better) and then polished it up.
It wasn't too bad - as long as I didn't look at the spot where the fix was. The next step was to decide where to place the fix. Trying a number of positions I opted for the "at the end of the clip" spot. yes, it is now being pointed out but when laying on its side the beautiful markings of the wood shows rather than "the spot".
This pen won't be going anywhere, but I'll enjoy using it and am pleased that the little piece of special wood wasn't tossed out.
Gallery
Comments
In Loving Memory
Great looking working Debbie !!!
I appreciated that.
Dave
It turned out really nice.
It's a good thing you salvaged it, & brought it back to life.
Hi Ms Debbie,
I will be trying my hand at pen turning some time in the new year, bought a lathe back in July, but have not had time to try it. Too much grass to mow, and mowed last weekend, hope it was the last time, and hope mine turn out as well as yours.
Jack
thanks everyone
the wood is SO beautiful and the history of it-i just couldn't let it go to the fire.
Great looking pen. Next time you think you may have chipout on a blank, get some marine grade epoxy and thin it with 15% acetone. It will be as thin as water and penetrate into the wood enough to give you a firm surface for turning. It strengthens the wood down to the bottom of every crack and every punky place if there is any decay. Mixed with sawdust it also makes a natural looking filler for voids and splits too.
Debbie, you are getting pretty good at turning these. One of the hallmarks of good craftsmanship (or more properly craftspersonship) :) is how well "oops" are covered. It looks like you did this well with the pen.
And thanks for the tips.
That one day I had problem after problem. I thought I must be doing something wrong.
Since then I've used wood hardener whenever I am unsure of the wood and one pen that had a definite line in it, I put crazy glue along the line. I held my breath with that one and "tada"-I got a pen!!
I should post that one.
Very very nice.
Great work MSdebbie and a super save.
Great job and super saver of the pen. You did very well.
Hi Ms. Debbie;
Great job!
They look good.
Now you are making long skinny hollow boxes that you can write with…lmagine that!
The failures make the successes so much sweeter. You did a great job on this pen and I don't see any flaws. I have never turned one of these, but I'm sure they are not all that easy to do.
yes Dennis-imagine that :)
You are so sweet to remember!
thanks Mike and Lee :)
Debbie, If we didn't learn something with every project we wouldn't enjoy woodworking as much as we do. Same as with life.When we stop learning we slide backward, knowledge just flows around us and leaves us behind. I think its a lovely pen & expect you will be reminded of what you have learned and probably use routinely on other projects.
you are right RTB.
and the wisdom gained (or reinforced) is that all things are to be honoured and I feel at ease with with the salvage and the end product of this special piece of wood.
Very nice Debbie. A great recovery.
looks spectacular…I know what you mean by honoring the wood--I am affraid to use the wood from Karson until I get a bit better…
sounds like you learned a lot…
