Project Information
I am currently working on a dollhouse for my daughter's 18" American Girl dolls. I decided I needed a new circ saw and crosscut guide for it.
The guide is 30" long, I don't think I have ever needed to square anything wider than 24". I used a left over piece of t track for my rail and cut a dado in the guide to match the rail. The most time consuming part was getting the rail parallel to the blade.
The saw is a Ridgid 6 1/2" from HD. I chose this saw because it is a couple pounds lighter than the larger diameter saws and it meets all my needs.
Gallery
Comments
I like it. all sorts or track options with just a 3/4 dado cut. very nice
That is really cool. Great job
Nice idea. Looks like it would work great.
did you have to drill the holes in the base of the saw or were the hole already there?
I had to drill and tap all of the holes, both in the base plate of the saw and the t track.
In Loving Memory
Very smart idea and it sure beats holding the saw against a rail.
What material are you using for the anti-skid stuff on the bottom of the track?
Don
That's pretty clever.
Never seen a miter bar on a circ saw before. Now that I have, I can imagine all kinds of uses. Why don't the manufactures make an option like this?
Good job, I like it.
Steve
Don
- Don "Dances with Wood" Butler
I am not sure what anti skid you are referring to. The base is simply 2 layer of 1/4 sanded plywood and a layer of 3/16 hardboard laminated together with a dado cut in it. The bottom layer is wider than the middle and top to allow it to be clamped to the work. The dado was cut using a 3/4" pattern bit and was cut about 1/16 deeper than the guide bar is thick.
I prefer laminating thin pieces vs. a single 3/4. I use 1 1/4 thick MDF stir treads (cheap and flat from Lowes) cauls to laminate the 3 thin sheets. This method gives me a flat and rigid base.
I agree with others great idea, might have to do that this weekend. Thx for sharing
That s pretty clever.
Never seen a miter bar on a circ saw before. Now that I have, I can imagine all kinds of uses. Why don t the manufactures make an option like this?
Steve
- SPalm
They are busy trying to reinvent the wheel.
The aluminum t track has a million good uses.
nice work here, another one I might have to give a try to as I cut a lot of sheet goods down… thanks for posting…
