Project Information
My shop build sander. I have looked at many plans on Lumberjock and came up with this. I did use hinges so that I could remove the table to more compact storage. Table is made of 2 - 3/4" MDF and 1 - 1/2" melmine. The drum is 22" wide. The only motor i had on hand is a 1/4 hp, takes a couple seconds to rev to top speed. but does a good job. I used 3/4 cold rolled steel for the shaft.
Price breakdown
20$ - 3/4 cold rolled steel
23$ - Pillow blocks with bearings.
35$ - 4X8 sheet MDF
7$ - pulley
30$ - 1/4 hp electric motor - Mine was free - can get cheap at auction.
10$ - 2×4 wood
5$ - belt - I had extra but plan to upgrade to link belt.
3$ - hinges
133$ Total, not bad. I have seen people spend up to 400 on shop made sanders.
Let me know if you have any questions. I do plan on building a hood with dust collection. That will be made with scrap wood around shop.
Gallery
Comments
Looks like it will perform well. Gotta love inexpensive shop builds!!!
Are you going with hook & loop for the abrasive paper?
Looks good from here
Did you give any thought to a feed belt just wondering?
What diameter is the drum?
Looks good. How will you handle the dust?
Jim
Jim
Nice looking project Chad. What did you do to make the table adjustable in thickness?
neat build i want a drum sander, but have struggled making one
with out pressing rollers how do u keep board from flying?
Using hook and loop sandpaper, threaded rod for table adjustment. Plan on making a dust hood, just have not gotten that far yet. Drum diameter is just under 6".
Elmo, you push wood against the direction of spin, with a push stick.
Looks nice, but don't forget to add some safety features. If your hands get caught in this home made sander, all of a sudden a factory made drum sander doesn't seem so expensive anymore…
What is the drum made from, and how did you get it perfectly round? Also, where did you get the pulley?
I've been considering this for awhile to complement the so-so portable thickness planer.
Hello Chad
Welcome to LJ's
A very nice project and a great work
Can you add a video to show your project in work ?
Thanks for sharing
Here is a video. Sorry about the glare.
Skyboy, Drum is made from MDF. I made a jig for my band saw to make the circles. Pictured above. This made them pretty round. I then put all MDF pieces on shaft and attached to stand. I then could raise the bed with a block of wood with sandpaper attached to level the drum to the bed, while the drum is on. I could move the block back and forth to work on place that weren't so level. After it was leveled to the bed I applied 3 layers of poly. Felt like glass after the poly.
Pulley I got from Farm and fleet. The size of the pulley (or difference in pulley) will determine the speed of the drum. I think I paid 5-6 $ for the pulley.
German, I do plan on making a cover for both the drum and pulley, thanks for the advice.
Nice Job!!
+1 For Paul's suggestion for dust collection!!
Very nice build. You are going to wonder how you ever got along without it. I use mine just about every day.
Great video, nice sander, thanks for sharing
