Project Information
After i purchased a Triton bench top spindle sander i was a little bit disappointed about its flimsy plastic housing and overall appearence. So dismantled the machine in just 30 minutes and build a new housing in Finnish birch plywood with a thick and sturdy melamine top. The solid construction brings noise and vibration back to a minimum.Three magnets are inserted into the front to hold a key wrench and a spare washer.
The removable guide/ pushbar is attached with a steele pivot point.
Gallery
Comments
Very nice work! It looks like a professional job! Hope it performs as well as it looks.
That's some top notch work. Most of my factory made tools don't look that good.
impressive.
Great project, I have the same spindle sander - different color - and it's loud, the spacer rings are not flat with the top… I am inspired to copy (ok, it won't be as nice as yours) this project! Thanks for posting!
That's awesome!
Couple questions:
1. Did you laminate melamine on all those surfaces (the black and white)? Of is the top just melamine and the sides are painted?
2. Dont take this the wrong way…... but I am curious why you didnt make the top surface bigger? If I were going to go through the trouble of taking my sander out of the original case and build a new one, I would want to make more real estate for the surface (beyond what you get with the stock sander). Maybe that's just me… anyway that doesnt take away from such a great build you have there.
Yes, you did a nice job with that. Never thought about or saw a removable guide/ pushbar …I'm not sure how it could be usefull? Doesn't the piece want to 'squirt' out?
al
This is a first class build from the embedded magnets, the routered hand holds, the discreet vents, the pivoting fence and melamine all around. I bet there are even rubber feet on the bottom. BTW, I'm a nerd for pivoting fences.
Great job - looks like the results you achieved will last a great many years longer. Well done.
It looks great ! I sold mine and now there are some times when I miss it. Alistair
I never thought of that. I have the HF version of the same tool and found that the top is just barely out of 90 deg to the spindle itself. Something like this could be useful.
What a great idea, great now another thing on my to do list. A+
I like it. Thank you for sharing.
great lookin sander. fine work, nice lines and curves
Fantastic! It looks much better than any plastic I've seen out there!
That's one grand rebuild.
Really cool idea.
Best thoughts,
Mads
