Project Information
I wanted a way to sand outside corners smoothly and quickly. Looking through one of Danny Proulx's books I came across his plans for this DIY version. Went scrounging at my local machine repair shop for a used motor with the right RPM and found one for a bargain price. Everything else is 3/4" plywood put together with pocket screws. There is a dust collection port under the motor and I wired it to a simple ON/OFF light switch.
The hardest part was fiddling with the actual plywood disc and the cheap pulley to get it perpendicular to the motor shaft. If you had access to machined pulleys they would make a better choice. You also want to use the flattest piece of ply for the disc.
On the piece of plywood is a adhesive backed piece of hook and loop. And then you just slap on a felt backed circle of sandpaper and voila!
Gallery
Comments
· Registered
I like Danny's books. He is very practical.
· Registered
Jeff, what is the proper speed and what is the diameter of the disc?
BTW nice job!
· Registered
Great job on this sander : )
· Registered
Coolness prevails great job.
· Registered
I have some old motors. I need one of these. Where did you get the hook and loop material and the sandpaper disk?
great job btw
· Registered
Since i don't have one…thanks for the idea
· Registered
It has it all, pocket screws, dust collection and adjustable table. Great job
· Registered
I started gathering parts this week to build me one these. Congrats on yours! I was snooping around for ideas and dims.
I'm going to try a "Quick-Disconnect Bushing" from McMaster-Carr in lieu of the pulley, McMaster P/N 6086K197. Don't know if it'll work or not, but it only costs $12.25 so not out much if it goes bust.
cc
· Registered
Great idea and effort! Thanks for sharing.
· Registered
Very resourceful….love it
· Registered
Simple yet awesome. I've got a couple of extra motors laying around that I was trying to figure out what to do with them… here is my answer. Very nicely done.
· Registered
well i know what tommoro nights project is now!... thanks!
· Registered
Very useful,great job. Can anyone tell can a bench grinder be used as disc sander?
· Registered
gul, do you mean directly onto the grinder disc? I'm not sure that would work very well as most grinders are fairly small diameter and you have the bolt in the middle. However you could probably use it to drive a pulley and belt system to which you could attach a larger disc. Basically you would be using the grinder motor just as I used an old motor.
· Registered
I just acquired a treadmill motor that I'm thinking of using for the same purpose.
· Registered
Jeff:
I just finished mine. This was an easy project for the most part. Well that is to say that I completed it in a day - sans finish. I used BB ply vs the MDF called for. I've never been able to put a screw in the edge of MDF and not have it split. Probably has a lot to do with the type of wood screws that I use.
I had a lot of trouble getting the table set to the correct location and square to the disc. The "home position guard" just wasn't cutting it. I ended up putting a wood screw in the edge of the "dust box" that the bottom of the table rests on to act as a positive stop. Did you have problems with this too? There could definitely be some real improvements made to this.
The miter slot is a nice touch. ++
Thanks for putting me on to this one. I had the Mag and didn't even remember this one being in it.
cc
