Project Information
Came across a simple end table design on the internet and thought to myself, "Hey, I could do that pretty easily".
Had a good time with this build, a lot of new challenges that I had not encountered before. First time doing long tapers, so I screwed some angle guides into my table saw sled (which I had just built for my last project). Also first time using water-based stain. That didn't go so well, the stain probably works just fine, but next time I'm going to see if I can stain before I assemble so I'm doing all my staining on flat surfaces.
Also, I "cheated" and used pocket holes on this. If I do this again I'm going to have the leg assemblies not over hang the table edges and do a dado joint to hold the two table tops.
Did a google search for ideas and found this: http://www.philtaylorantiques.com/mission-oak-furniture/oak-hexagonal-stand-table/
Gallery
Comments
Great table. Thanks for the in process pictures. It is nice to see how some of the parts are made. Don't you just love using a sled??
Cheers, Jim
Very Nice Work Indeed! Thanks For Sharing!
I did a "Wall Niche" using Water Based Stain. Will Never Use It Again! It hides The Grain! Oil Base Stain ONLY From now on.
Rick
Great design and very well executed. Like the finish, it came out really good looking. Great job!
-www.sawblade.com
