Project Information
After buying the Harbor Freight 2hp dust collector right after Christmas, I knew I was going to be making some changes to it. First, I dumped the upper bag and added a Wynn 35a filter. Second, I really wanted to put a pre-separator on the unit to keep from having to change the lower bags as often. But, I didn't really have a lot of room in my shop/garage for the can. The Delta 50-760 seemed like a good set up with the can/separator underneath the blower, so I set out to imitate that set up. That led me to build a frame to mount the HFDC motor/blower and raise it up so I can get a can under it. I used 2x material and plywood with a healthy dose of glue and screws for the frame. After some trial and error, I got the unit mounted directly in line with the donut ring. The flex hose is a piece that was cut off of the original 5" hose that came with the unit. The two sides are actually touching, it's just there to ensure a good seal.
Next came the Thien lid on a 30 gallon galvanized trash can. I used the lid that came with the can and just cut holes in it with my dremel. I did add some weather stripping around the edge to get a good seal. The piece in the middle is a Delta 5" to 4" reducer that leads from the 5" outlet on the blower to the can. Again, the flex hose is a piece I cut off from the original that came with the unit. I need to get some hose clamps to fit that connection. Right now I'm using zip ties and it's not air tight. The inlet port is a simple 90 degree black plastic piece. Everything is held in place with hot glue/caulk.
I did a couple of tests on the unit to see how much was staying in the can and it's working quite well. I did see a reduction in air flow with the addition of the pre-separator, but that's to be expected. At least now I'll preserve my filter and won't have to hassle with the lower bag for a while.
BTW: I added weather stripping on the area where the lower bag connects to the donut ring. It made an airtight seal and I don't get ANY leakage now.
I hope this helps you guys. Any questions please feel free to ask. Thanks for looking.
Cory
Gallery
Comments
· Registered
Isn't that a Thien baffle you have installed there? (Sorry, gotta give Phil proper credit for his design…)
What size weather stripping did you use?
I have had mixed luck with mine and can't quite remember the size I used that worked well (but the adhesive didn't last…)
That is a VERY tempting idea. I like the ability to keep it mobile that you kept with your design. I think I am going to start playing with some ideas to hook my 55 gallon separator / HF DC up like that… Putting the motor in that orientation certainly gets rid of a lot of resistance to airflow…
· Registered
dbhost: Yes, it's a Thien baffle/lid. Sorry for the confusion. I give credit to Phil for his design (second paragraph), but I should have been more clear. He's a genius, btw. The weather stripping was 3/4" wide, 5/16" thick. I made sure to clean the inside of the lid with alcohol then let it dry really well. It's stuck so far, but we'll see how it holds up. Moving the motor up (without the pre-separator) made a HUGE difference in air flow. The separator probably killed most, if not all, of those gains, though. I have the expandable hose from Rockler, so the unit pretty much stays put, but i do roll it around occasionally. It's been working well so far.
· Registered
That's a great idea, and very well executed.
I really should…..
Nicely done!
· Registered
I have been thinking of doing this for a while also. I just hate to hear chunks hit the impeller in my little Jet (3/4 hp). Last night I rigged up a similar configuration just to see how well it would work. (no baffle & I just duct taped the lid on - the connections I had caulked the night before.) It lost a lot of suction. It would barely pick up sawdust. So I was really disappointed. I am assuming it is just too small to handle it.
· Registered
That looks good.
· Registered
That col. How does that compare to one of those tapered vortex collectors? I have been looking for a design for mine and I ,too ,want to use the Harbor Freight collector pump.
· Registered
I've been debating the possibility of doing the exact same thing with my Jet DC-1100C. As you can see, it is the same basic design as the one from HF. Now that I've seen it actually done, I think I'll move forward with it..
BTW, anyone want some flex tubing? As you can see, I've got A LOT.
· Registered
Jim: I assume you mean a cyclone? The Thien lid functions much the same way, but a true cyclone is a different animal all together. In my limited testing of this set up, I would say the Thien lid removes 85-95% of what's coming in. Only the finest of particles seem to make it to the bag. I put this whole set up together for about $250. That's $150 for the DC and $100 for the can, hose, lid materials, etc. That's a whole lot cheaper than a cyclone!
Rick: Let me know if you need any other pictures or help when setting up yours.
· Registered
That is fantastic, I just got this unit from HF this past weekend. Just out of curiosity, why didn't you use the base that comes with it normally? More work to fit wood to metal than to just make a new one out of wood?
· Registered
Chase: I didn't use the metal base because it isn't long enough for the support frame for the motor. Also, it's an easier connection from the 2x material to the old solid core door than to metal. I had the old door laying around the shop so I just used it. If I was doing it from scratch I'd probably use 3/4" ply and add a rib or two underneath for rigidity.
· Registered
Cory,
Nice Job. You've given me the incentive to do something similar. This setup is the way to minimize the DC footprint and maximize dust collection!
· Registered
Nice job , Cory : )
· Registered
Hey Cory, that is what I was thinking of doing with my dust collector. I would think that using a smooth pipe for the inlet on the trash can might gain some airflow.
· Registered
Another nod for the Thien baffle. I did a similar setup but ran the exhaust outside of my shop using a 7" dryer vent and a 5-6 inch reducer along with a 6-7 inch reducer. Works great and is really pretty quiet!
· Registered
Wow, that is a nice rig for $250… Makes me want to buy a new dust collector! Does that include the filter? Where did you get the Wynn 35a filter?
· Registered
Alright, so how well does the Thein Seperator work in your use so far? And how much would you say it reduces the ability to actually collect?
I really like this idea, and have just acquired the HF DC.
Have anyone of you had any problems upsizing the ducting. Bill Pentz recommend 6" ducting, and according to his information you can reduce your airflow by having too small of a duct size. So I'm wondering if this machine with a separator and larger than 4" ducting would work better, than sticking with the 4" ducting. I'm also hoping that by keeping the ducting runs shorter the airflow will remain as high as possible with the other reducing elements in the system.
· Registered
The thien baffle works well enough to fill the trashcan with shavings and dust, without sending much if any ( claimed 95% or greater) to the filter or the collection bag. My experience has shown this to be fairly accurate. As it is, the baffle simulates a cyclone and the slot keeps the dust and debris from re-entering the air flow path.
If you want to go with larger ductwork, the max that will be of use with the HF DC is 5". Larger than that will not allow any greater airflow, due to the intake size restriction of 5"
· Registered
Lee: I don't have a measuring tool, so it's difficult for me to quantify the loss of suction with the Thien lid. I can tell you that I got a huge increase when i moved the blower in line with the ring and then lost most, if not all, of that increase when I installed the lid. The Thien lid probably removes 95%+ of the material that passes through it. I just planed quite a bit of white oak and cherry and hardly anything passed on to my lower bag. I think the true test will be when I cut/sand MDF. I haven't done that, yet.
