Project Information
I do a little carving on some of my projects & found that the store bought mallets are made for giants. Both the grip area & the overall length are way too long. The only solution was to turn my own.
Since I like using baseball bat billets of maple & ash for some of my projects like pepper mills, I thought I would get an Ash billet at Woodcraft for the mallets. I found a nice pattern for a "Goldielocks" mallet that was just the right size. But after turning the first mallet I found that the mallet was a little light & was best used for lighter more shallow carving. Soooo I cut a blank to length & bored a hole in the business end. I used the hole on the live center end of my lathe & turned another mallet with the same dimensions as the first but burned a marker ring to easily identify which mallet was which. After completing & finishing the majority of the mallet I crammed a few lead muzzleloading round balls in the end & plugged the hole. Now I have two mallets of identical shape with different weights. I like the feel of using the same size mallet that delivers more inertia without using hardly any more muscle.
Gallery
Comments
In Loving Memory
Well done.
You will appreciate your own work every time you use them too, very nice!
Just hammer away the way that works BEST for YOU!.
Premium Member
A great idea! The mallet I have is also too big for most of the carving I do. Have you weighed your two mallets? What is the overall & handle length?
Very nice..
Nice mallets! I'll have to consider using weights instead of changing the mallet size. I have giant hands though, so I have the opposite problem.
