Project Information
Wood And Materials Used
red oak, pine
Tools Used
radial arm saw, miter saw, table saw, band-saw, lathe, planer, drill press, belt sander
Location
Fairbury, Illinois
When I was a kid on our farm in Central Illinois, we had a vertical elevator we used to lift grain and then send it to our bins, or to trucks. This elevator had a long vertical belt with steel buckets bolted to the belt. The belt and buckets took the grain to the top, then it fell off and went down round pipes to its destination.
A couple years ago, I made my first wood chain, so I got the idea, why not use wood chain instead of a rubber belt to lift the carriers??
My idea was to design a wood marble carrier that would attach to the wood chain links:
I used Sketchup, so here is the whole model in Sketchup:
Since kids can crank at up to 100 RPM, and I needed the model to run at just 5 RPM, I used a wood worm gear for the necessary 20:1 speed reduction ratio.
It turned out designing the carrier was the most challenging part of this project!! Here is a loading sequence diagram for the carriers:
Lots of trials & tribulations on this project. You can see my woodworking web site for all the details using this link. I uploaded my model to the Sketchup Warehouse, and there is a link on my web site to the Sketchup model.
I made a YouTube video of this model in action. You can see the video using this link.
Now it is ready for the grand-children endurance tests !! They should have fun with this one.
Gallery
Comments
· Premium Member
I think this is the most complex and best of your mechanisms.
Congratulations
· Registered
Well done DM... in both the model and presentation.
Love it when presenters put a little effort into presenting their creation(s) that have taken ages to design and build... yet fat too many just slap up 1 photo and 1 simple sentence...
This gives the opportunity for others to imitate... plagiarism is a great form of compliment.
Just an aside... If I may make a suggestion... place those alignment lines in you SketchUp diagranm into a hidden layer. I usually place permanent solid alignment lines on circle centers and slap them onto a $Guidelines layer. That way you can keep them permanently in the model (as opposed to traditional guidelines) and hide/reveal the layer on demand while "assembling components"... I do the same with circles that are used for swing of items, (X-Ray on for demo)...
Just toggle the layer on/off...
· Registered
Very well done, really like the wooden chain and your design. thanks for sharing your process and the write up on this. One of these are on my list of to build one day. (Grandkids also)
· Registered
Always enjoy seeing and reading about your projects. This is another great one.
· Registered
Congratulations
Thanks !! The last one I did that used 3 big wood wheels to raise the marbles was about as challenging of a project.
I think the most challenging was the big marble machine that automatically runs out 26 marbles over 16 minutes. Lack of any good directions made it extremely difficult to figure out how all the internal mechanisms worked !!
· Registered
Thanks for the tip!!
I started with Sketchup Version 7, which was free, and have kept using it all these years. I occasionally use Version 2014, because it lets me export high resolution drawings, typically for signs. When Sketchup switched to an annual paid subscription model, I just kept on using my trusty old free Version 7 :)
Version 7 doesn't have any layers features, but if I ever switch, I will check out the layer thing. Thanks again :)
· Registered
Thanks!!
My website has all the blow by blow details of doing this project.
The only issue with the wood chain design I have used on 2 projects is there is nothing to keep the inner links separate, except the radius'd edge of the sprocket. When I transport the toys to a showing, sometimes the bouncing around in the truck causes the links to come together, and I have to separate them before the model will work. There are other designs that use a hollow plastic pipe mounted over the wood dowel, which keeps the spacing right. I try to avoid using plastic in my models, so I haven't tried that design out.
thanks again
Dale
· Registered
Here is a thought to keep the links at the correct spacing. If I can explain is words. The center section has the pins to hold the outer in place, what if that pin had a shoulder that would stop the outer from compressing tight to the inner section. Would probably need to fashion another jig to create that shoulder though.
· Registered
DM, Sorry to deviate from this great project, but I'm not a fan of PMs as it lacks editing features... at least the old version did and I hate this new version.
SU 2016 is the latest free version that supports 32 bit processors (2017 is 64 bit only) though its a tad harder to find the downloads. I may be able to provide links to the free version if you chose to upgrade as it may be hard to track down as Trimble are trying to force people into the WEB or subscription version.
· Registered
Excellent.
Phil
· Registered
The Sketchup Warehouse still accepts my models done in Version 7. The only time I run into trouble is if I want to download somebody's design from the Warehouse, and the downloads are restricted to the newest versions, not way back to version. When that happens, I have to figure out how to convert a new model back to Version 14, which is the other free version I occasionally use, then save in version 7 from version 14.
· Registered
Here is the design I have been using, which is very simple, but the 2 inner links can move together and not fit on the sprocket.
Another option would be to have a shoulder on the connecting pins. The shoulder could be a 1/2" dowel turned down to 1/4" on the ends, or a 1/4" dowel with a short piece of hollow plastic pipe with a 1/4" ID to fit over the dowel.
In this model, there are 42 connecting pins, would take quite a while for me to make 42 of these on the lathe. And, I would have to change the sprocket design to handle the 1/2" versus 1/4" dia of the pins.
One could also center drill short pieces of 1/2" wood dowels on the lathe with a 1/4" hole, which would be must faster than turning down one piece. Maybe I will experiment on a future project with one of these alternative methods.
Thanks!
· Premium Member
Really cool :cool: We need videos!
· Registered
I made a Youtube video of the model in action, you can see it using this link.
Thanks
Dale
· Registered
Nice video, and a wonderful build.
