Project Information
I have been "making due" when working on/restringing guitars or banjos for my whole playing life. I use a pillow normally to support the neck, but for the last couple of years, as I have gotten more and more into properly setting up and repairing instruments (...notably ones that get dropped off the roof of a car…), I have wanted a proper neck rest. I really like the StewMac version that is round, but it is made of wood, so I can't just go and buy it… That is just crazy talk! I did what any of us on LJ would do: I just copied it and made my own.
I had some left over beech counter-top that I glued up (3" thick and in a 9" square) and made it round on the lathe with the final diameter being 8.75". I bored a hole in the center and enlarged it with a bowl gouge. After getting it all round, smooth, and the hole in the center added, I pulled it off the lathe and went to work on the bench: Cutting 1/3 off and then made a channel with a rasp and sanding wheel (chucked up in the lathe) on the two flats of the larger piece. Some hide glue, a leftover bit of cork, clamping pressure, trim-out of the cork with a razor, and I finally have a proper neck rest.
Side note: I made the hole in the center about 2.75" so that the 5th string tuner on the banjos would clear. See 3rd and 5th picture.
Gallery
Comments
In Loving Memory
Awesome work. I made mine from some plastic pieces I found out beside the highway then covered the sharp parts with chunks of saddle leather.
I should figure out how to make one like yours without using a lathe!
- Dallas
It can be done with a band-saw and a shaper or belt sander. I don't have the latter two, so the lathe was the most expeditious. Cut a 5-7' block in a radius. use the shaper with a 2+ in spindle or the round edge of the belt sander to make the center "cut out. Turn and so the same to the two flat areas.
