Project Information
Grill table backsplash I made with Red Cedar. Resawed the cedar and planed it to 1/4 in. then cut it into boards about 3 in. wide and added a bead with a moulding head on the table saw. If you take a close look it's obvious it was not a "professional" job, lol, but I have come to accept my humanity and realize that I am not a pro. Using solid wood as a paneling I should have left a little space for expansion, so it buckled a little in a couple of places. Still, I'm happy with it. Finished everything with three coats of Helmsman Spar varnish. I also made a beverage cooler to match. The plans called for using a certain size cooler with a drain in it, but I couldn't find that size - nor worries I thought - I had some 1 in. thick foam board insulation laying around so I cut it to size and glued it in place. Only later did I find out that foam board will absorb water, so now I'm going to make a plastic box to fit inside. Is there any other way to learn besides the hard way? Thanks for looking
Gallery
Comments
Looks quite professional from here.
Yes, there is another way. Learn from other peoples mistakes. :)
It all looks good and creates a nice space for grillin.
Premium Member
What an awesome space you have created here! Good job, congratulations!
super project! That took a while, but great results.
