Project Information
Some quick Christmas presents I made just today for my brothers and sisters. Took only a couple hours. Made of Mahogany, and one out of Walnut. 2 coats of Red Mahogany Danish Oil.
And yes I realize that isnt a wine bottle in there (I dont drink wine). Its an old Vodka bottle I started putting coins in. haha - still works though
For a project like this, should I be putting a topcoat on, like a poly or something, or do you think just the Danish Oil is enough??? Thanks
Gallery
Comments
I go Danish Oil, but I'm lazy. :)
Nice presents.
jamie
Those are sweet. Do you have the angles/dimensions on those? I'd love to make a couple for gifts as well.
the oil shuold be enoff and buff the last coat you give so they shine a little
Dennis
Great job !
I've given two as gifts. They ARE a crowd-pleaser!
You can flood-coat a coat or two of Danish Oil, and then-once those are good and dry-wet sand (@ 400 - 600 grit wet/dry paper) the last coat or two. Leaves a beautiful finish.
No NEED for the poly, on top, unless you want the extra sheen-personal preference.
Dak, those are very nice and I'm sure they will love them. Good job.
Nice job on these! They are pretty easy to crank out once you get the formula down, wouldn't you agree? I like the oil idea. Maybe a quick final wax coat if you have some?
I'm in the middle of making a handful of these as gifts as well.I will probably either do Danish Oil or Waterlox, as I have both that need to get used up. Especially if I go the DO route, I'll probably throw on a topcoat of Renaissance Wax. My dimensions are pretty similar to yours. The only thing I've definitely decided to change was the width. A lot of people make them less than 3-inches wide. I made the first one at 2-3/4" wide, as the pattern I was copying called for. That's fine if you've got narrow stock, or minimal scraps to use up, but I've decided to widen mine a bit, so they're 3+inches; I didn't care for the look of them being narrower than the bottles they are holding. At 3-inches wide, they're about the width of a Bordeaux bottle (the one that is tall and narrow and has a sharp shoulder to it), while a Burgundy bottle is a bit wider (the one that has a lower shoulder with a more gradual shape to it).
Fantastic. I'm making a bunch of these as gifts for family and friends.
Thanks for sharing.
