Showcase cover image for Glass Top Barnwood Hall Table
Project Information
A month ago I got the opportunity to purchase about 28 boards of barnwood and while sorting through the pile I saw this one board and right away I knew what the end project was going to look like. Once I cut the board to size I started my drawings and shortly after I began constructing the table. It measures 52" wide, 13 1/4" deep, by 32" high. It took some figuring out to find a good way to stabilize the "fragile" barnwood. I ended up using liquid nails and a couple (20 or so) drywall screws to secure it to a piece of 3/4" mdf. The glass is rabbeted into the edge trim. The drawers are machine cut dovetails with a chamfered edge detail. Finish was done with a flat black paint, rubbed through, then a cherry gel stain on exposed areas finished off with a few coats of wipe on poly. The base is constructed of solid maple. It was a fun quick project.
Gallery
Comments
a great combo of elegant and rustic well done
Very nice imagination!
"Quick" project?! Arg. Great piece. Great use of old wood. I've been trying to think of ideas for some old barn wood I have. I like that you get to preserve the original wood while at the same time showcasing it.
Now that's different ….great job and an awesome idea : )
This really caught my eye. The top is such a great display case for that old wood. I really like the simple lines and finish as well. Kudos.
Nice work, I really like this piece. I do a tremendous amount of work with reclaimed lumber. We recently did a 260" counter top in a home theater out of reclimed chestnut and used 1/2 MDF as a backer as well. I find that I have about a 25% attrition rate with the stuff. It also really tears up my knives and my hands :). I like to run my pieces lightly on the jointer, just enough to get it flat but not enough to take off all of the paint and ageing. after that I flap sand it and shoot it. It really looks nice, especially if the barn was painted red!!!
Very well done! You found a great way to use the fragile piece, and show it off as well. Love it!
looks great from here well done Alistair
