Project Information
I drew duckmilk as a recipient for this swap, and knowing he has a forge and anvil I wanted to make a forging hammer. After seeing his collection (with some crafty help from fellow swappers and friends) I decided on a dogshead hammer, aka cutlers hammer or sawyers hammer. It's a weight forward design best suited to thin precise work such as knife bevels or saw blades.
It started as a 1-1/4×2" stick of 4140 steel bar. I milled the eye (which was an experience of its own as I work hardened it multiple times until I got the right speed & feed sorted out- I'm still learning the machinist ropes!)
Next I decided to taper the bottom which made it resemble an axe head.
Here it is getting the sides cleaned up before sanding the whole thing to 120grit
2.69lbs- it's got a good feel to it!
I decided to use some pecan from my yard that has been drying in the shop for a couple years to make a handle.
I hope duck gets some great use out of it!
Gallery
Comments
Good job! Nice choice for duckmilk.
Well, awesome hammer! The taper is a nice feature and adds grace to the project. And your project make me want to explore the metal side. Though the heat treating it out for me
Thanks guys! This one is not heat treated, it's pretty tough steel as-is and since it'll be used for thin work I feel like it'd be very easy to hit the anvil face so I wanted the hammer to be softer than the anvil. I told duck if he decides it's too soft I'll gladly harden it though! If anyone else needs heat treat done I've got an oven now!
Premium Member
You metal working guys put the rest of us to shame. Just looking at the picture, I could tell it had to be a hammer used around a forge. No frills, all business, or as Kenny would say - that's a sexy beast.
I also need to find some pecan. Seems like everyone was using it this swap.
Very nice buddy, and very original. Duck should get a lot of use from it.
You do good work. Really good work.
Awesome job Grant!!! I would use that sucker at the anvil any day!
I think it is awesome Grant! I don't foresee it needing to be any harder than it already is. I would rather re-dress any dings in the hammer than damage something I didn't intend to. The folks at work who got to see it were really impressed. And, I was proud to show it off :)
That's a well made hammer. The home grown Hickory was the icing on the tool.
The handle looks properly indexed.
How's the balance?
Superb build,
Very very nice that, and the home grown Pecan handle a real treat.
Nice one
Superb build,
Nice one
- anthm27
Oops meant the Pecan-Hickory.
Anthm27 are you in any danger living in Hong Kong?
Premium Member
pecan wood really sets this mallet off GREAT JOB :<)) GRATZ TOP 3
Great job Grant! I'm sure it will serve Duck very well!
I'm getting the idea there are as many metal workers here as woodworkers. A lot of companies would be proud to have as many solid products in their line as you guys are putting out.
Congrats.
That thing with a bit of grinding is a hatchet with azz.
Nice job Grant. Different kind of mallet for a different kind of Duck, um, I mean guy ;) I know he'll put it to good use.
