Project Information
Feb 16, 2012
I know several of you have built one of these and Iʻve been wanting to do the same to make using my table saw safer. I found the article that appeared in Woodworkers Journal Jan-Feb 2009 and used it as a guide. Of course Iʻve made modifications.
Most of the white surfaces that you see are 3/4 inch high density MDF that has melamine on one side.
I started by making the extension a little deeper than the article dimensions using 2 pieces of the MDF glued together. I also put a hardwood bands around the MDF surfaces to protect it. I attached the extension to the back of saw by drilling thru the angle iron which is part of the Biesemeyer fence system.
I then attached a piece of 3/4 inch plywood to the back of the cabinet to a point almost touching the dust port. I then attached additional supports (not in the plans) to support this massive extension. Also not in the plans are the addition of bumper stops right above the shelf that supports the fold-up support.
This shows the support holding the outfeed table. If you zoom the pictures and look closely at the right side of the support (where the barrel bolt catches are attached) you will see that I added another piece of wood not called for in the plans. The reason that was required is because the screws supplied with these heavy-duty barrel bolts were longer than the wood I was screwing it in so I added another piece of wood ….
This is the top view of the outfeed table in position, ready for work.
This is the outfeed table in the stored position. Notice the notch on the back edge of the outfeed table? After building it, I realized that the outfeed table extended about 1 inch beyond the dust port. This would not allow me to connect my dust collection hose to the dust port with the outfeed table in the stored position. This notch was the solution to solve that problem. With a small shop, some times I need to fold the outfeed table down to do other operations.
This is a massive outfeed table and is very sturdy. It should add convience and safety to my table saw use.
UPDATE: Since posting this project, Iʻve found that in my small shop this outfeed table makes a good work surface/assembly area.
Thanks for looking. Comments welcomed. Have a great day.
PS: I found where I got the article. Go to the following link:
Fold-Down Outfeed Table article.
Gallery
Comments
· Registered
Alex;
Great adaptation of the WWJ version. Like your idea to get additional length on the O/F end. Luckliy my dust port is on the side of my TS so I can extend mine to about an inch off the floor when folded down. My saw is alo on Mobil base so it's about 2" taller than most tables saws. I have an assembly table behind my TS that I use for out feed but have often found I need to use TS when the table is loaded with a build. This looks like a solution to solve my problem.
Thanks for sharing. Adding to my favorites.
· Registered
very nice job there
· Registered
Wow, as I was looking at your pics, I was thinking that is a beefy outfeed table, way better than the one I was thinking of making. Very nice job on that. Oh yeah, nice saw as well.
· Registered
This is sooo totally on my TO-DO list!
Great job!
· Registered
Wow, this is fantastic. I really need to make one of these. Thanks for the pics and writeup!
· Registered
You're being stalked, I mean favorited (if that's a word)!
Unfortunately I have a contractor saw on a,so I will need to modify this design. I am however highly motivated by your project.
Thanks, for sharing!
· Registered
Really nice I also used the wwj plan also I really like your version better Great job
· Registered
I see all these neat out feed tables and this one is very nice,,, and I have an external motor and I am limited to what or how I can build a table, have to make an offset in the table to accommodate the motor on a 45*,,one day I will have a cabinet saw,
· Registered
That's a great build. I have the same saw and would like to make the outfeed table like yours. I looked for the magazine online but it's out of print so I ordered the 2009 disc so I can get the plans Thanks for posting!
· Registered
Well, that should be a great safety enhancement, wonderful job
· Registered
Nice out-feed table.
· Registered
This is a really nice outfeed table design.
Thanks for sharing.
· Registered
Great work on this, looks amazing!
· Registered
Very cool.
I am doing a similar table on my saw. I made a blog post about it: http://lumberjocks.com/timbit2006/blog/28173
The only differences are the way it's mounted and the folding section support.
Mine will have angle iron and folding legs. I chose to use legs so It doubles as an assembly table.
How low do you have the surface of the outfeed table in relation to the saw top?
· Registered
Tyrone -
The plans for the outfeed table said to set the top of the outfeed table about 1/16 inch lower than the surface of the table saw top. That is how I set mine..
The angular support is really nice cause you wonʻt be running into it when working around the outfeed table. Mine seems sturdy enough to serve as an assembly table. I leaned on it and it didnʻt show any tendency to tip.
· Registered
Saved cause this will be on my too do list
· Registered
look all pictures,i see,very nice design,thanks sharing
· Registered
very nice i been wanting to build one for my table saw
