Project Information
I got tired of lifting my planer or kneeling on the ground. Time to build a cart.
This is based on the Wood plan with a nod to the Woodsmith "small shops" cart.
The case is made of two layers of 3/4" luan plywood, edged with redwood. I used all scraps for this project except for the steel rod, casters, and eye bolts. Total cost around $20
It took me about two weekends to make this.
I let the drawer overhang the shelf, so that I did not need a handle. I am not sure what to store in the drawer or which tool will reside on the flip side.
It was fun to build, and I can reach the planer, roll it, and a bit more storage too.
Repost of the video from my prior blog
Just because you want to see it flip.
Gallery
Comments
· Registered
Great work!... I bet you could fit a smallish Belt/Disc sander on the other side.
· Registered
Got this one on my list of things to build. Maybe my planer on one side and the Ringmaster on the other?
· Registered
Great job. I'm with Caj…, A machine on both sides-a "tewfer".
· Registered
Nice project. You could put one of your less used smaller tools on it- bench grinder maybe. Or simply use it as a small work space.
Anyway it is a very useful project.
Now let's put it to use and make something else.
· Registered
great job and great blog , thanks again for spending your time on it
· Registered
Great Job, with nice design- smaller version would be perfect for bench grinder -
Did you find the height a little high for your planner - would suggest a little short for more stock control?
But it is truly a fit form and functional piece- nice job
· Registered
I will probably get an OSS at some point and it will find a home there.
Bill. I am not sure what you mean about the height.
· Registered
John: A great cart. Nice job with the construction.
· Registered
A great utility piece Jon. I liked the blog too.
