Project Information
So during my woodworkers meeting early this month, I had brought up the need for a CNC machine in my shop and after further discussion my fellow woodworkers mentioned laser CNC said it would be better than router in doing sharp and crisp corners. The $400 machine was brought up sold on Ebay, the high end machines are in the 5k and up range which is way out of my budget and need.
So the next day I started researching and reviewing both the X-Carve and the cheap china laser machines and found issues with both and during my research it had dawned on me that Laser was no more than wood burning and I knew that I already had a Colwood pyrography machine and started comparing via google images done by both hand and laser and was amazed at what can be done with a Pyrography machine. I saw no difference between the two aside the fact that my pyro machine takes up less real estate in my shop.
You'll start to see more of my projects in pyrography as I progress in my adventures but for now here are a couple of pieces that I did in my practice. The first plaque was a test turn for an urn I'm about to build and the second plaque was a test run of what I can do when signing my work pieces on the bottom.
The wood used in the pictures was Alder.
