Project Information
Having always been drawn to the looks of finger joints, I decided I simply must build this jig when I watched a video showing the construction by its designer. I went to the website, looked at all the info and bought the plans. After a very enjoyable weekend in the shop i varnished it up and waited patiently for it to dry so I could try it out.
Nearly everything used in the construction was scrap, you know, all the short pieces we all have piled up in the corners that are "just too good to throw away". Cherry, mahogany, walnut. cedar and birch plywood. I did have to buy a short piece of 3/8×3/4 aluminum for the slide.
As many of you probably already know, stock to be cut is clamped vertically inside the center box and the gears are used to advance the material across the blade in a controlled fashion. I still find myself looking for things to store in a finger jointed box. It's just so very satisfying to quickly crank out a good looking little project.
I've got little boxes like this all over the workshop, and not just for woodworking tools!
Go out to the workshop and make yourself some tools! You will never be happier to do a little work than when you are using a jig or tool you have crafted for yourself! Make it fancy, it doesn't take much longer and you will smile every time you use it. Happily, I'm in this for the fun of it.
Gallery
Comments
Great project, awful pretty
ive had the plans for that and his bandsaw for years, but still havent built them. One day perhaps
Excellent build. Really like you finished it up nice and made it look like a tool not some wood on the table.
TOP NOTCH!!
Who did you get your plans from?
Kool, I have the luxury of a lazer cutter for gears and greatly appreciate anyone that cuts gears using conventional tools.
Neat jig (from an avid jig maker).
Very nice! A quality jig (or tool) inspires quality work.
TOP NOTCH!!
- woodbutcherbynight
Looks like Mattias Wandels designs @ woodgears.ca
Mark, I like the work you have done. It is careful craftsmanship. Thanks for posting this. I am intrigued. Could you please direct us to the You Tube site so we could watch it work and maybe the site where you got your plans?
- Tugboater78
I agree it does look like it but his has a large main gear, much larger than this one appears to be. Perhaps in his plans he changed this aspect?
You are correct! The plans were indeed from Mattias Wandel. His website (woodgears.ca)has tons of plans and there's a YouTube channel as well. He has a four part video series on the construction of this box joint jig.
Search "box joint jig matthias wandel" on YouTube and you'll get the entire series and then some.
I found the plans to be very easy to use especially after printing them out full size. This is under joinery jigs on his website, the screw advance box joint jig.
The gears are changed for different width sawblades, thats why the gear on mine doesn't match the original. It's really very easy to make up a bunch of gears right on your bandsaw.
Thank you all for your kind words. This was a fun project.
Nice job and craftsmanship! I built the same one and it works great! The plans from Mattias Wandel are very, very well done! They are clear and well illustrated. And the cost if the plans very, very reasonable!
