Comments
good job.
Nice Work.
That's a neat looking piece of wood and you have used it well
Wow that looks awesome! Do you drill all the way through with your candle holes, or just partially so they sit in there?
Re : BrandonR
Drill partially thru timber
Tea light candles are about 15mm deep , the timber is 38mm
I use a 38mm 1/12 inch Spade Bit !!
I use a drill press and set the stop depth to the depth of teal light candles !!
If you are using a drill, put tape around spade bit to depth you want to stop at !! stop just before tape mark & check depth for each hole !!
Regards
Anthony
Anthony thanks for the response! I will try it out! Thanks!
Anthony, what finish did you use? I am looking at doing a small project with tea light candles and I was just a little concerned about how hot the candles get and whether the heat would damage either the wood itself or the finish applied to it.
Re : Tootles
To get that finish , I found a great technique to highlight grain texture !!
I sprayed the entire candle holder Matt Black , when dry I sanded it , the black paint stays in the hollows of the wood !
I then stained it with Cabbots Mahogony stain , then Gloss laquered it ( via spray can as well )
I discovered that technique of spraying Black , when i made a mistake one day !! after I sanded a piece of timber with knots, I realised it was the best way to highlight grain flow & character in timbers !!
Hope this helps !! give it a go !! it's amazing how effective it is !!!
Regards
Anthony
Thanks Anthony. I think I have some Cabbots on a shelf somewhere, I will have to try it.
I agree with you. This wood is very special and it really works well with the candles.
