Comments
Great Idea, Gene!
Wish my table say had a solid wing. Maybe I could make a cross brace to capture below the webs in the wing.
Thanks for sharing!
PS- I like the red warning areas, too!!
Lew
Nice work, good to use feather boards.
Gene: A great addition of a couple of safety items. The feather board and the red warning areas.
I am curious, why didn't you make the feather board to work with the miter slot?
dbhost,
With the slotted way that I have made it, I can run stock twice as wide as you can with a regular feather board mounted in the miter slot. Plus it cost relatively nothing to make. Thanks for the question.
God bless
Premium Member
Good idea Gene, looks like is should get the job done. i do teh same thing, drill holes and modify as necessary to get the job done :)
solid feather board !!! I also like the red for the danger zone…awesome idea
Seen a lot of feather boards, but your red warning areas are a fantastic idea! Bet you have at least half of your fingers!
nice featherboard. I glue a piece of sandpaper on the bottom of mine. once u lock it down, it's not movin
Real good featherboard. As it happens I'm making one tomorrow as I need it for a particular job. Did have one sorted but having seen yours I'm going that way instead. Like a comment before I'm not sure why I can't use my T slot with bolts and still have a slot in the timber for different sizes of stock, but I'm probably missing something, it'll probably all come clear when I make it. Just got to find that old tin of red paint. Thanks for sharing Gene.
