Project Information
This is a more conservative combination of woods. It's one of the more simple combinations of wood that I've done, but I've shaped the handle to be as ergonomic as possible and with some nice design to it to give the user a sense of style. (I am trying to abolish those ugly aluminum and simple stick canes.) The handle is made of moderately figured Claro Black Walnut and the shaft of Figured Cherry. It's a nice "safe" combination of colors and grains.
Your comments are welcome.
For more information please visit my Gallery here at lumberjocks.com: http://lumberjocks.com/jocks/mmh/projects and my other websites: http://www.bigstickcanes.com or http://www.gallerymh.com
Gallery
Comments
Sweet!
I have been curious about something with many of your cane handles. Other than the burls and seed pod handles, most look like the grain is almost vertical. Does this compromise the strength of the handle or is it reinforced internally? I am not making any canes, just curious. If this is a trade secret, I'll understand!
Lew
Very good point and observation. I can only use the grain vertical if the wood is dense enough to endure the stress. I can usually tell when working with a piece if it's hard enough or not. Claro Walnut is one that can range in density and so the tighter the grain and direction it moves will determine if it's dense enough to shape. My handles are thicker than the normal ones found and I do have to be careful of going too narrow if the wood is not really dense. Otherwise I would use the grain lengthwise for ultimate strength. The Macadamia handle is a good example on how thin I can go when a wood is strong enough and using a cross section of wood: http://lumberjocks.com/projects/11552
When I customize a cane I make sure I know the needs of the user and their weight range so I can determine how much stress the cane will have to endure. For example the Lychee & Marblewood cane was made for a fellow who is quite heavy and needs to lean his full weight on it. Both of those woods are extremely hard and the shaft was cut into a dowel on top as one piece and joined into the handle completely through, giving it superior strength and joinery http://lumberjocks.com/projects/10704 .
Otherwise I use a long inner dowel along with the two side dowels to make sure the joinery is stable. My handles will never "wiggle" off like the cheaply made ones.
Unfortunately you can't tell how hard these woods are unless you can hold them and feel their weight, but most of them are excellent candidates for Skull Crackers.
Thanks for the inquiry.
Wow, you got another winning piece of usable art. I'm still thinking a book is in order.
-Jon
another nice looking cane.
Another great looking cane. And you have our resident Artisan posting. Mark just got better internet service so he can stay on longer now.
Great job.
